With IE 10 is this a CORS setup issue or an ArcGIS 10.2 queryTask issue?
3708
04-24-2015 11:00 AM
BlairJones
I'm still loosing sleep over my ArcGIS JavaScript application and why it does not work with IE 10 / 11.  I have CORS enable my server, which seems to work with everything not ArcGIS and works with for ArcGIS showing feature layers on a map, but not for queryTask directed at the same feature layer.
I have the JavaScript directive, though not supposed to be needed:
// where getTokenURL="https://some.domain.gov/arcgis/tokens"
esri.config.defaults.io.corsEnabledServers.push(getTokenURL.split("/")[3]);
Everything works properly in Firefox, Chrome, and Opera.  But in  IE10
my $.getJSON CORS request works well, the map loads and displays images as expected.  When I execute a queryTask the nework trafic monitor shows a request being made through PROXY instead of a CORS request.  Firefox, Chrome network monitors show CORS requests for the same event.
My authorization token is valid for the Client IP address, not valid for the PROXY IP; things go wrong.
My question is, have I missed something I need to do or does ArcGIS 10.2 queryTask not support IE 10 / 11 CORS ?
Good health!
Blair
