Widget Cleanup Throws Error
1845
02-05-2021 11:51 AM
developerarce
Following this guide: Feature Filters
When moving to another route (react) or effectively "cleaning up", I get thrown the following error in console.
Uncaught DOMException: Failed to execute 'removeChild' on 'Node': The node to be removed is not a child of this node.
If I remove the line of code `view.ui.add(filterExpand, "top-left");` then I have no issues. I am not sure what I am doing wrong, because the guide above has no explicit cleanup.
My code:
const Map = (props: any) => {
  const classes = useStyles();
  const mapDiv = useRef(null);
  useEffect(() => {
    if (mapDiv.current) {
      const filterStuff = (stuff: any, view: any) => {
        const data = stuff.getAttribute("data-stuff");
        // const test =
        view.filter = new FeatureFilter({
          where: `stuff='${data}'`
        props.handleStuff(data);
      const renderer = ...
      const geoJSONLayer = new GeoJSONLayer({
        url: ...,
        renderer: renderer,
        outFields: ["*"]
      const map = new ArcGISMap({
        basemap: "topo",
        ground: "world-elevation",
        layers: [geoJSONLayer]
      const view: any = new SceneView({
        container: mapDiv.current!,
        map: map,
        camera: {
          position: {
          tilt: 0
      const filterElement = document.getElementById("stuff-filter");
      view.whenLayerView(geoJSONLayer).then(function(layerView: any) {
        // set up UI items
        if (filterElement) {
          filterElement.addEventListener("click", function(event) {
            filterStuff(event.target, layerView);
          filterElement.style.visibility = "visible";
          const filterExpand = new Expand({
            view: view,
            content: filterElement,
            expandIconClass: "esri-icon-filter",
            group: "top-left"
          //clear the filters when user closes the expand widget
          filterExpand.watch("expanded", function () {
            if (!filterExpand.expanded) {
              layerView.filter = null;
              props.handleStuff(null);
  return (
      <div id="stuff-filter" className={classes.filter}>
        {items.map((item, index) => (
          <div className={`FilterItem ${classes.filterItem}`} data-stuff={item}>{item}</div>
      </div>
      <div className={classes.mapImage} ref={mapDiv}></div>
Tags (1)
developerarce
Solution:
Before
  </div>
After
    </div>
  </div>
developerarce
Solution:
Before
  </div>
After
    </div>
  </div>
