Why my graphics are not added to the map?
4724
12
12-04-2012 08:01 AM
YvanBérard
Hi all,
I'm following this example (but programmatically) http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/find_map_datag...
and I don't know why my graphic are not showing up...
Thank's for your help.
//display the location results on the map
function showResultsLocator(results)
    map = getMap();
    //find results return an array of findResult.
    console.dir(map); // my map object is fully working here
    map.graphics.clear();
    var dataForGrid = [];
    //Build an array of attribute information and add each found graphic to the map
    var cpt = 0;
    //console.log(results);
    dojo.forEach(results, function(result)
     cpt++;
     var graphic = result.feature;
     //console.log(graphic.attributes.NAD83+","+ graphic.attributes.CIVIQUE+","+ graphic.attributes.VOIE);
  dataForGrid.push([result.layerName,graphic.attributes.NAD83, graphic.attributes.CIVIQUE, graphic.attributes.VOIE]);
        var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.5]));
        graphic.setSymbol(symbol);
  map.graphics.add(graphic);  // the graphics are not added to the map. Why?
 //console.log(dataForGrid);
 generateTableSearch(dataForGrid);
 //console.log("cpt search = "+cpt);
 $('#nb_res_search').empty();
 $('#nb_res_search').text('Nb. résultat(s): '+cpt);
YvanBérard
Even this doesn't work....
I can see in my DOM object that my created layer( var mySearchLayer = new esri.layers.GraphicsLayer({ id: 'search_result' }); ) have all of my search result and their geometry, but they are still not showing.
What's wrong with that????
BenFousek
I'm not sure. Zip up you app and post it or send it via a private message and I'll take a look.
YvanBérard
After digging up my problem with Mr. Fousek (btfou), he found that my graphic are added to the map but with a totally wrong extent.
This is my original extent:
var initialExtent = new esri.geometry.Extent({ 'xmin': -8034661, 'ymin': 5652797, 'xmax': -8004182, 'ymax': 5670187, 'spatialReference': new esri.SpatialReference({ wkid: 102100 }) });
But, when the event add(graphic) is fired, the graphic are added in the middle of the mediterannean sea (?!?!?!???). How could this happen? I've never seen that bug.
var graphic = new esri.Graphic(result.feature.geometry, sym); //create graphic with geometry (result.feature.geometry) and symbol (sym)
        console.dir(map);
        map._layers.search_result.add(graphic); //add graphic to graphics layer created above
