Why my graphics are not added to the map?
4752
12
12-04-2012 08:01 AM
YvanBérard
Hi all,
I'm following this example (but programmatically) http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/find_map_datag...
and I don't know why my graphic are not showing up...
Thank's for your help.
//display the location results on the map
function showResultsLocator(results)
    map = getMap();
    //find results return an array of findResult.
    console.dir(map); // my map object is fully working here
    map.graphics.clear();
    var dataForGrid = [];
    //Build an array of attribute information and add each found graphic to the map
    var cpt = 0;
    //console.log(results);
    dojo.forEach(results, function(result)
     cpt++;
     var graphic = result.feature;
     //console.log(graphic.attributes.NAD83+","+ graphic.attributes.CIVIQUE+","+ graphic.attributes.VOIE);
  dataForGrid.push([result.layerName,graphic.attributes.NAD83, graphic.attributes.CIVIQUE, graphic.attributes.VOIE]);
        var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.5]));
        graphic.setSymbol(symbol);
  map.graphics.add(graphic);  // the graphics are not added to the map. Why?
 //console.log(dataForGrid);
 generateTableSearch(dataForGrid);
 //console.log("cpt search = "+cpt);
 $('#nb_res_search').empty();
 $('#nb_res_search').text('Nb. résultat(s): '+cpt);
BenFousek
I think its how you are creating the graphic using var graphic = result.feature;. That doesn't create a esri.Graphic object.
Here's the execute of an identify task.
t.execute(p, function (results) {
    if (results[0] != undefined) {
        var r = results[0].feature;
        var atts = r.attributes;
        var sym = app.sym.SimpleFillSymbol('solid', new esri.symbol.SimpleLineSymbol('solid', new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.2]));
        var it = new esri.InfoTemplate('My Info Title', 'My Info Content')
        var graphic = new esri.Graphic(r.geometry, sym, atts, it);
        map._layers.MY_GRAPHICS_LAYER.add(graphic);
YvanBérard
No, my feature object is all right.
When i use FireBug to inspect the object, I have all what a graphic object should have...but nothing happen.
JeffPace
I agree, I don't think result.feature is a graphic either.
Can you show what result is?
YvanBérard
Here some proof taht they are both graphic object...
When I use my identification tool (queryTask) the feature object return (using console.dir(result.feature)) :
[ATTACH=CONFIG]19722[/ATTACH]
And when I use my search tool (where my graphics are not added to the map) the feature object return (using console.dir(result.feature));
[ATTACH=CONFIG]19723[/ATTACH]
BenFousek
I ran a test and was surprised to find you can create a graphic object that way. The problem I encountered with your method was setting the symbol. Sometimes it didn't take. The graphic was in the map but had no style. It I would create a esri.Graphic as best practice.
Also, create your own graphics layer. I had trouble in the past with map.graphics and quit using it some time ago.
What does the graphic object look like in the DOM @ map.graphics; is it even present?
YvanBérard
Yes, at the beginning I though it was the map object the problem, so then I a create setter/getter functions, but in the DOM @ map.graphics the object was present even without the setter/getter functions.
How do you do that? And what trouble did you have?
BenFousek
Graphics layer:
var plotGraphics = new esri.layers.GraphicsLayer({ id: 'plot_gl' });
app.map.addLayer(plotGraphics);
Notice that I set the id of the layer. You should always set the id of all layers: dynamic, tiled, feature, graphic, etc. It's a lot easier to find a layer when you named it yourself. All layers are located in the map._layers object.
The problem with map.graphics is that it isn't a true graphics layer per se. It's built into the map and is always the top most layer. So reordering is a problem. Like I said, I haven't used map.graphics in a while, but I recall having some issues with my apps being unstable, slow or crashing when I used map.graphics. That was pre v2, so it's probably fixed by now. Most of my apps have 6-10 graphics layers and up to 20 or so feature layers. Being able to reorder and have better control over graphics layers is a must in that situation.
YvanBérard
Maybe I don't understand.... but what I want to do, is to create a graphic from the result of my findTask.
So why should I create a new graphic layer? And if I really need to use a new graphic layer (new esri.layers.GraphicsLayer) , how could I pass the result of my findTask to the new graphic layer?
BenFousek
After you initialize the map add your graphics layer:
var myGraphicsLayer = new esri.layers.GraphicsLayer({ id: 'my_graphics_layer' });
map.addLayer(myGraphicsLayer);
Add features:
function addResultsToMap(results) {
    dojo.forEach(results, function(result) {
        var sym = esri.symbol.SimpleFillSymbol('solid', new esri.symbol.SimpleLineSymbol('solid', new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.2]));
        var graphic = new esri.Graphic(result.feature.geometry, sym); //create graphic with geometry (result.feature.geometry) and symbol (sym)
        map._layers.my_graphics_layer.add(graphic); //add graphic to graphics layer created above
        //OR
        //map.graphics.add(graphic); //add to map.graphics
I didn't add attributes or an info template to the graphic object; both are optional.
