Why can't I add my points to my map after changing variables?
4560
07-17-2015 02:26 PM
ChrisSergent
I updated variable in my application and it was adding supports and signs before, but now it's not. I have an updated project at: csergent45/streetSigns at ee7def64d6ffd77f78e7a9516e10942a8951b6f8 · GitHub  Here are the two blocks of code that appear not to work:
// get attributes from form and submit
    var addSupports = function () {
        //alert(domClass.contains("attributesModal", "in"));
        var attributes = {
            // TODO: not sure if this is needed
            //requestreceived: null
        var currentDate = new Date(); // current date is defined but never used.
        var graphic;
        graphic = new Graphic(app.currentGeometry);
        query("#attributesModal input, #attributesModal select, #attributesModal textarea").forEach(function (formInput) {
            attributes[formInput.name] = formInput.value;
        // Form Validation - ensures that the values for the database are here if left blank
        if ((attributes.SUPPORTID === undefined) || (attributes.SUPPORTID === "")) {
            attributes.SUPPORTID = null;
        if ((attributes.DATEINV === undefined) || (attributes.DATEINV === "")) {
            attributes.DATEINV = null;
        if ((attributes.ADDRCODE === undefined) || (attributes.ADDRCODE === "")) {
            attributes.ADDRCODE = null;
        //graphic.setAttributes(attributes);
        stopCaptureRequest();
        //console.log(attributes);
        app.supportLayer.applyEdits([graphic], null, null).then(function (response) {
            console.log(response);
            app.supportLayer.refresh();
// get sign attributes from form and submit
    var addSigns = function () {
       // alert(domClass.contains("attributesSignModal", "in"));
        var attributes = {
        var graphic;
        query("#attributesSignModal input, #attributesSignModal select, #attributesSignModal textarea").forEach(function(formInput) {
        // Form validation - ensures that the values for the data are here if left blank
        if ((attributes.sign_INSTALLED === undefined)|| (attributes.sign_INSTALLED === "")) {
            attributes.sign_INSTALLED = null;
        if ((attributes.sign_SIGNID === undefined) || (attributes.sign_SIGNID === "")) {
            attributes.sign_SIGNID = null;
        if ((attributes.sign_SUPPORTID === undefined) || (attributes.sign_SUPPORTID === "")) {
            attributes.signSUPPORTID = null;
        attributes.supportId = attributes.sign_SUPPORID;
        delete attributes.sign_SUPPORTID;
        app.signLayer.applyEdits([graphic], null, null).then(function (response) {
            app.signLayer.refresh();
The forms for each of these are as follows:
Support Form
 <!-- attribute editor modal Begin -->
    <form id="supportForm">
    <div id="attributesModal" class="modal fade" style="display: none;" aria-hidden="true">
        <div class="modal-dialog">
            <div class="modal-content">
                <div class="modal-header">
                    <button type="button" class="close" data-dismiss="modal" aria-hidden="true">×</button>
                    <h4 class="modal-title">Add/Edit Street Support</h4>
                </div>
                <!-- Street Support Modal Body Begin -->
                <div class="modal-body">
                    <div class="form-group">
                        <label for="OBJECTID">Object ID</label>
                        <input type="number" class="form-control" name="OBJECTID" id="OBJECTID" readonly>
                    </div>
                    <!-- Address Begin -->
                        <label for="ADDRESS">Address</label>
                        <input type="text" class="form-control" placeholder="Address" name="ADDRESS" id="ADDRESS" />
                    </div>
                    <!-- Address End -->
                    <!-- Begin Support ID -->
                        <label for="SUPPORTID">Support ID</label>
                        <input type="number" class="form-control" name="SUPPORTID" id="SUPPORTID" />
                    </div>
                    <!-- End Support ID -->
                    <!-- Begin Type -->
                        <label for="TYPE">Type</label>
                        <select id="TYPE" class="form-control" name="TYPE" required>
                        </select>
                    </div>
                    <!-- End Type -->
                    <!-- Begin Size -->
                        <label for="SIZE_">Size</label>
                        <select id="SIZE_" name="SIZE_" class="form-control" required>
                        </select>
                    </div>
                    <!-- End Size -->
                    <!-- Begin Material -->
                        <label for="MATERIAL">Material</label>
                        <select id="MATERIAL" name="MATERIAL" class="form-control" required>
                        </select>
                    </div>
                    <!-- End Material -->
                    <!-- Begin Base -->
                        <label for="BASE">Base</label>
                        <select id="BASE" name="BASE" class="form-control" required>
                        </select>
                    </div>
                    <!-- End Base -->
                    <!-- Rating Begin -->
                        <label for="RATING">Rating</label>
                        <select id="RATING" name="RATING" class="form-control" required>
                        </select>
                    </div>
                    <!-- Rating End -->
                    <!-- Date Inv Begin  -->
                        <label for="DATEINV">Date Inv.</label>
                        <input type="date" class="form-control" name="DATEINV" id="DATEINV" />
                    </div>
                    <!-- Date Inv End -->
                    <!-- Inspector Begin -->
                        <label for="INSPECTOR">Inspector</label>
                        <input type="text" class="form-control" placeholder="Inspector Name" name="INSPECTOR" id="INSPECTOR" />
                    </div>
                    <!-- Inspector End -->
                    <!-- Comments Begin -->
                        <label for="COMMENTS">Comments</label>
                        <input type="text" class="form-control" placeholder="Comments" name="COMMENTS" id="COMMENTS" />
                    </div>
                    <!-- Comments End -->
                    <!-- Address Code Begin -->
                        <label for="ADDRCODE">Addr. Code</label>
                        <input type="number" class="form-control" placeholder="Addr. Code" name="ADDRCODE" id="ADDRCODE" />
                    </div>
                    <!-- Address Code End -->
                    <button id="btnSupportSubmit" class="btn btn-success" type="submit" style="visibility:hidden">Submit</button>
                    <button id="btnSupportUpdate" class="btn" type="submit" style="visibility:hidden">Update</button>
                    <button class="btn btn-default" type="button">Cancel</button>
                    <button id="btnRelatedSigns" type="button" style="visibility:hidden">Signs</button>
                </div>
                <!-- Street Support Modal Body End -->
            </div>
        </div>
    </div>
    </form>
    <!-- Attribute editor modal End-->
Signs form:
 <!-- Attributes Sign Modal Begin -->
    <form id="signForm">
        <div id="attributesSignModal" class="modal fade" style="display: none;" aria-hidden="true">
            <!-- Modal Dialog Begin -->
                        <h4 class="modal-title">Add/Edit Sign</h4>
                    </div>
                            <label for="sign_OBJECTID">Object ID</label>
                            <input type="number" class="form-control" name="sign_OBJECTID" id="sign_OBJECTID" readonly>
                        </div>
                        <!-- Mutcd Begin -->
                            <label for="sign_MUTCD">MUTCD</label>
                            <select id="sign_MUTCD" class="form-control" name="sign_MUTCD" required></select>
                        </div>
                        <!-- Mutcd End -->
                        <!-- - Begin -->
                            <label for="sign_INSTALLED">Installed</label>
                            <input type="date" class="form-control" name="sign_INSTALLED" id="sign_INSTALLED" />
                        </div>
                        <!-- Installed End -->
                        <!-- Sign ID Begin -->
                            <label for="sign_SIGNID">Sign ID</label>
                            <input type="number" class="form-control" placeholder="Sign ID" name="sign_SIGNID" id="sign_SIGNID" />
                        </div>
                        <!-- Sign ID End -->
                        <!-- Facing Begin -->
                            <label for="sign_FACING">Facing</label>
                            <input type="text" class="form-control" placeholder="Facing" name="sign_FACING" id="sign_FACING" />
                        </div>
                        <!-- Facing End -->
                        <!-- Visibility Begin -->
                            <label for="sign_VISIBILITY">Visibility</label>
                            <select id="sign_VISIBILITY" class="form-control" name="sign_VISIBILITY" required></select>
                        </div>
                        <!-- Visibility End -->
                        <!-- Condition Begin -->
                            <label for="sign_CONDITION_">Condition</label>
                            <select id="sign_CONDITION_" class="form-control" name="sign_CONDITION_" required></select>
                        </div>
                        <!-- Condition End -->
                        <!-- Support ID Begin -->
                            <label for="sign_SUPPORTID">Support ID</label>
                            <input type="number" class="form-control" name="sign_SUPPORTID" id="sign_SUPPORTID" />
                        </div>
                        <!-- Support ID End -->
                        <!-- Text Begin -->
                            <label for="sign_TEXT">Text</label>
                            <input type="text" class="form-control" name="sign_TEXT" id="sign_TEXT" />
                        </div>
                        <!-- Text End -->
                        <!-- Color 1 Begin -->
                            <label for="sign_COLOR1">Color 1</label>
                            <select id="sign_COLOR1" class="form-control" name="sign_COLOR1" required></select>
                        </div>
                        <!-- Color 1 End -->
                        <!-- Delineator Begin -->
                            <label for="sign_DELINEATOR">Delineator</label>
                            <select id="sign_DELINEATOR" class="form-control" name="sign_DELINEATOR" required></select>
                        </div>
                        <!-- Delineator End -->
                        <!-- Illum Begin -->
                            <label for="sign_ILLUM">Illum</label>
                            <select id="sign_ILLUM" class="form-control" name="sign_ILLUM" required></select>
                        </div>
                        <!-- Illum End-->
                        <!-- Offset Begin -->
                            <label for="sign_OFFSET">Offset</label>
                            <input type="text" class="form-control" name="sign_OFFSET" id="sign_OFFSET" />
                        </div>
                        <!-- Offset Ends -->
                        <!-- Mountht Begin -->
                            <label for="sign_MOUNTHT">MOUNTHT</label>
                            <input type="text" class="form-control" name="sign_MOUNTHT" id="sign_MOUNTHT" />
                        </div>
                        <!-- Mountht End -->
                        <!-- Backing Begin -->
                            <label for="sign_BACKING">Backing</label>
                            <select id="sign_BACKING" class="form-control" name="sign_BACKING" required></select>
                        </div>
                        <!-- Backing End -->
                        <!-- Width Begin -->
                            <label for="sign_WIDTH">Width</label>
                            <input type="text" class="form-control" name="sign_WIDTH" id="sign_WIDTH" />
                        </div>
                        <!-- Width End -->
                        <!-- Height Begin -->
                            <label for="sign_HEIGHT">Height</label>
                            <input type="text" class="form-control" name="sign_HEIGHT" id="sign_HEIGHT" />
                        </div>
                        <!-- Height End -->
                        <!-- Txt Size Begin -->
                            <label for="sign_TXTSIZE">Text Size</label>
                            <input type="text" class="form-control" name="sign_TXTSIZE" id="sign_TXTSIZE" />
                        </div>
                        <!-- Txt Size End -->
                        <!-- Num Size Begin -->
                            <label for="sign_NUMSIZE">Numsize</label>
                            <input type="text" class="form-control" name="sign_NUMSIZE" id="sign_NUMSIZE" />
                        </div>
                        <!-- Num Size End -->
                            <label for="sign_COMMENTS">Comments</label>
                            <input type="text" class="form-control" name="sign_COMMENTS" id="sign_COMMENTS" />
                        </div>
                        <!-- Two Sided Begin -->
                            <label for="sign_TWOSIDED">Two Sided</label>
                            <input type="text" class="form-control" name="sign_TWOSIDED" id="sign_TWOSIDED" />
                        </div>
                        <!-- Two Sided End -->
                        <!-- Attach Type Begin -->
                            <label for="sign_ATTACHTYPE">Attach Type</label>
                            <select id="sign_ATTACHTYPE" class="form-control" name="sign_ATTACHTYPE" required></select>
                        </div>
                        <!-- Attach Type End -->
                        <!-- Attach Num Begin  -->
                            <label for="sign_ATTACHNUM">Attach Num</label>
                            <input type="text" class="form-control" name="sign_ATTACHNUM" id="sign_ATTACHNUM" />
                        </div>
                        <!-- Attach Num End -->
                        <!-- Attach Loc Begin -->
                            <label for="sign_ATTACHLOC">Attach Loc</label>
                            <select id="sign_ATTACHLOC" class="form-control" name="sign_ATTACHLOC" required></select>
                        </div>
                        <!-- Attach Loc End -->
                        <!-- siteObs Begin -->
                            <label for="sign_SITEOBS">Siteobs</label>
                            <select id="sign_SITEOBS" class="form-control" name="sign_SITEOBS" required></select>
                        </div>
                        <!-- siteObs End -->
                        <!-- Sign Shape Begin -->
                            <label for="sign_SIGNSHAPE">Sign Shape</label>
                            <select id="sign_SIGNSHAPE" class="form-control" name="sign_SIGNSHAPE" required></select>
                        </div>
                        <!-- Sign Shape End -->
                        <!-- Color 2 Begin -->
                            <label for="sign_COLOR2">Color 2</label>
                            <select id="sign_COLOR2" class="form-control" name="sign_COLOR2" required></select>
                        </div>
                        <!-- Color 2 End -->
                        <button id="btnSignSubmit" class="btn btn-success" type="submit" style="visibility:hidden">Submit</button>
                        <button id="btnSignUpdate" class="btn" type="submit" style="visibility:hidden">Update</button>
                        <button id="btnSignPrevious" type="button" style="visibility:hidden">Prev</button>
                        <button id="btnSignNext" type="button" style="visibility:hidden">Next</button>
                    </div>
                </div>
            </div>
            <!-- Modal Dialog End -->
        </div>
    </form>
    <!-- Attributes Sign Modal End -->
Any ideas?
RobertScheitlin__GISP
Chris,
  You were not suppose to change the form elements NAME property just the ID.
In your code you use query to get all the form element by their class and type and then use:
which mean that the name property of the element needs to match the attribute name.
    <select id="sign_ATTACHLOC" class="form-control" name="ATTACHLOC" required></select>
</div>
You also have a mistake in your signs code:
line two should be:
attributes.sign_SUPPORTID = null;
ChrisSergent
Should I change the names back?
Chris,
   Yes Change the names only and leave the ids the way you have them.
ChrisSergent
Thanks Robert Scheitlin, GISP​; I was assigned a new project and got pulled off of this, but I am going to try it now. I will mark it as answered as soon as it is working. So I am going to try this now.
ChrisSergent
I can now add a support, but I can't add a sign and I can't apply edits to anything.
I have updated the newest version of my code here after changing the names back: csergent45/streetSigns at 5d2a9cbcb8e94aa08b55afc5c0143dbe9657fcca · GitHub
Any ideas why it's not applying or why I can't add a sign?
