Why are Graphics Layer Points are offset at higher zoom levels?
1272
11-03-2016 08:27 AM
Swani_Jesus_Captonsiluvairajan
This happens on the Map control of my JS API application.  JS API V 3.15
When I zoom in, the graphics layer draws points with offset.  This only happens if I go higher than zoom level 19.
Zoom level 19
zoom level 23
My Map service uses the Spatial Reference: 102100  (3857)  and the layers use the same.
There are no offset set in the Marker Symbol!
here are the coordinates
Graphics in the selection layer : {"x":-8236542.608046744,"y":4972503.374560848,"spatialReference":{"wkid":102100,"latestWkid":3857}}
Same point in ArcMap Layer :     "x":-8236542.608046744,"y":4972503.374560848
Graphics in the selection layer drawing location at zoom level 23 :    "x":-8236542.689359816,"y":4972503.365381212
The Point as drawn by Map service   at zoom level 23  is at  :            "x":-8236542.502745978,"y":4972502.171052645
