Which esri-servers load KMLLayer
696
04-08-2025 09:42 PM
SokoFromNZ
Hi guys,
I'm successfully loading/showing KML files on the map like this:
export function setPlotKmlLayer(uri) {
    require(["esri/layers/KMLLayer"], (KMLLayer) => {
        const kmlLayer = new KMLLayer({
            url: uri
        view.map.add(kmlLayer, 0);
        plotLayer = kmlLayer;
The uri points to a public endpoint of our own webservice. For security reasons I want to restrict the access to this endpoint so only the esri-servers can access it.
Is there a fixed domain from esri which always access my endpoint?
I found KMLLayer.kmlServiceUrl which has a default value of https://utility.arcgis.com/sharing/kml. So it should be utility.arcgis.com. But is this guaranteed?
thanks
Soko
SokoFromNZ
I was able to log the requests on our endpoint.
It seems that IP 34.234.176.30 does the request for the KML file. Which DNS wise resolve to
ec2-34-234-176-30.compute-1.amazonaws.com
