Are there any best practices for representing symbols with real world orientations
749
04-04-2025 08:58 AM
JonathanDawe_BAS
I'm tracking a vessel's location in my application, and the symbol on the map is rotated based on its heading.
The problem is that this rotation is applied relative to the screen's Cartesian coordinates, rather than the map's actual spatial reference system.
I understand that adjusting for this isn’t straightforward—especially in projections where a straight line doesn’t follow a constant compass bearing (like polar projections).
Right now, I manually calculate the correct angle based on the projection, position, and bearing, while also accounting for map rotation. This is quite complex and requires map rotation watchers, and projection specific logic.
(view in My Videos)
Is there any built-in way to handle this automatically?
JonathanDawe_BAS
Alternatively if this is not possible I can raise this as a separate idea?
JonathanDawe_BAS
Just to add to this... What I've discovered is that if you use a picture marker then it will maintain its rotation with respect to the underlying basemap as the view is rotated. Where as if you use a vector marker it rotates its frame of reference with the map as it rotates.
Is this a bug? Its really counter intuitive and doesn't seem to be documented anywhere?
