Where to download JSAPI 2.0 for a local install
6266
7
08-16-2010 08:52 AM
JohnMonnett
I have previously been using a local install of the JSAPI 1.3 JavaScript and was able to make a few modifications to the JS in order to use my local Dojo with both my web app and the ArcGIS API.
I was not sent the JSAPI version 2.0 and would like to do the same as I had done with JS 1.3.
I have tried using the xdomain configuration but there have been many problems and so far things are not working using that technique.    Note, am using Dojo 1.5.
I hope someone has done the same (local install of JSAPI 2.0) and can enlighten me.
Thanks - John
KellyHutchins
Esri Notable Contributor
John,
You can download a local copy of v2.0 of the api from the ArcGIS Resource Center.
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_faq.htm
JohnMonnett
Thank you very much - John
JohnMonnett
When will the JS 2.1 be available for download ?
I am currently using 2.0 with Dojo 1.5 but would like to use the compatible version 2.1
KevinGooss
I too would like to update my local version. Wonder why we can't just download the library the same way the browser does and then serve that?
KellyHutchins
The 2.1 download is now available from the FAQ page in the ArcGIS API for JavaScript help. http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_faq.htm
ZhenyaMihailovs
Is it possible to configure local JS files with relative paths?
shay-geo
Not sure, if this is true ...
Is there any performance issues, when you run JS API from the local server instead of ESRI server? Or it is same or depends on functionality? Has anyone encountered the performance problem before?
Thanks and Regards,
Shail_GIS
