When clicking a point graphics, popup does not open
2966
02-21-2016 05:42 PM
sw1
I am trying ArcGIS JavaScript API 4.0 Beta 3.  The project is ASP.NET 5 / MVC 6.  Point graphics can be rendered.  But when clicking over a point, the popup does not open.
Thank you very much!
Tags (1)
syangL
It works! but might with a bug.Try to click at the bottom right of the point.
sw1
Thank you.  But no!  The sample provided by ESRI works.  But when plug that in a ASP.NET 5 / MVC project, it does not work.  It is not related to where you click.  I believe it is related to CSS comes with ASP.NET 5 / MVC 6.
Any one has the similar experience?
Thanks a lot.
MichaelMatuszak
Is your map flush with the top-left edge of your page?  If not, it seems there is a bug in 4.0beta3 where the click target is offset by whatever the margin is.
PopupTemplate click target offset if any margin
sw1
Thanks.  I think you are right.  This might be the case.
