What do I need to modify to insert my data?
7934
14
04-10-2015 12:39 PM
ChrisSergent
I am attempting to modify this responsive web design sample and need to replace the information that was originally inserted to use our data instead. The code that I need to modify for the form named attributesModal is in the main.js file within the app folder and the HTML page that has the form is index.html. My project is here: csergent45/streetSigns · GitHub and you can run it here: Street Signs
What do I need to do to get this to work?
Here is the original form:
and here is my form:
KellyHutchins
Esri Notable Contributor
Have you tried setting a breakpoint in the code at that spot and stepping through the code? While doing so check the value of the variables at that point - perhaps something is undefined?
ChrisSergent
This was the change that I actually needed to make. There was a template in the web service and I did not have all of my fields with a name attribute in the HTML and the address was listed first in the template. One I added the name attribute to the all fields and placed address first, I was able to insert data and it displayed on the map.
Thanks!
williamcarr
Can it log any attributes?
ex.
var hydrantRecord = evt.graphic.attributes.Number;
console.log(hydrantRecord);
ChrisSergent
I am getting data back. See my post above to Kelly.
ChrisSergent
The array did relate. I used Kelly's example and had to re-arrange my data as well as add the attribute "name" to my form fields.
