Web URL to *.png file for PictureMarkerSymbol
3289
06-22-2020 02:27 AM
ChristianBischof
I am trying to achieve the following:
I'd like to use a png file as the marker symbol for my PictureMarkerSymbol, but it seems like it's only possible with local png files
What doesn't work, but I'd like to achieve:
var markerSymbol = {
          type: "picture-marker",
          url: "https://www.myurltothepicture.com/img/mypicture.png",
          height: "60px",
          width: "60px",
What works, but isn't what I need:
          url: "local/path/to/png/symbol.png",
          height: "60px",
          width: "60px",
Does anybody know if this is generally not possible, or am I doing something wrong?
I'm using JS API 4.15
Thanks in advance for your help
Egge-Jan_Pollé
Hi Christian Bischof,
Yeah, the easiest way is to use an image hosted on the same domain as the application. That works, as you have already noted.
Alternatively:
To avoid CORS issues with this symbol, do one of the following:
More info here: PictureMarkerSymbol | ArcGIS API for JavaScript 4.15
HTH,
Egge-Jan
Egge-Jan_Pollé
Alternatively:
HTH,
Egge-Jan
ChristianBischof
Thanks Egge-Jan Pollé‌ then I got it right, but it's not possible to simply add something like this to the url property?
url: "https://i.stack.imgur.com/ILTQq.png"
Egge-Jan_Pollé
No, apparently not... When your image is hosted in a different domain as the application, you should make sure that the server the image is hosted on is CORS enabled. Or you should install a proxy...
When I tried this sometime ago (Aan de slag met ArcGIS JavaScript - CSV bestand toevoegen), I ended up using the most simple solution: I copied the image to my own server. I did not (not yet) get one of the other two options to work, so I am not able to give you any insights into these...
BR,
Egge-Jan
ChristianBischof
Thanks Egge-Jan Pollé‌ that's exactly what I've done right now, because it's the easiest way.
