Vulnerable Javascript in Story Map Shortlist
2556
03-21-2016 07:54 PM
BenMak
Hi all! Need somebody helps..
I am using a shortlist story map template (Story Map Shortlist | Story Maps) to making my story map.
However, the jQuery version (jquery-1.7.2.min.js) in this template was detected as a vulnerable Javascript library by the web application security (acunetix) in my institute based on this link http://research.insecurelabs.org/jquery/test/.
My institute requests me to use the non-vulnerable one in order to publish my map and I found out that my story map is not working when I click the 2nd point on the map if I use other versions of jquery...
