Can anyone help with getting the legend, overview, and scalebar to show when using an ArcGISDynamicMapServiceLayer?
4000
5
03-21-2016 01:02 PM
RichardLafleur
Here is my code so far. I need the third map in the dropdown to do the same thing the first two do. When chosen the third map should refresh with a scalebar, overview window, a legend found on the legend tab, and the title of the map.
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Map</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script src="https://js.arcgis.com/3.16/"></script>
    <script>
      require([
        "dojo/on",
        "dojo/parser",
        "dojo/ready",
        "dijit/layout/BorderContainer",
        "dijit/layout/TabContainer",
        "dijit/layout/ContentPane",
        "dijit/form/ComboBox",
        "dojo/dom",
            "dojo/dom-construct",
        "esri/map",
        "esri/urlUtils",
        "esri/arcgis/utils",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/dijit/Legend",
        "esri/dijit/Scalebar",
        "esri/dijit/OverviewMap",
        "dojo/domReady!"
      ], function(
        on,
        parser,
        ready,
        BorderContainer,
        TabContainer,
        ContentPane,
        ComboBox,
        dom,
            domConstruct,
        Map,
        urlUtils,
        arcgisUtils,
        ArcGISDynamicMapServiceLayer,
        Legend,
        Scalebar,
        OverviewMap
          ready(function(){
            var map, legendDijit, scalebar, overviewMapDijit, legendLayers;
            parser.parse();
            var select = dijit.byId('mySelect'); // element to reference for event listener below
            select.on('change', function(evt) {
              // event listener - do something here when select value changes
              updateMap();
            }); // end on
            function updateMap() {
              var selection;
              //Delete all existing map-related components
              if(map != undefined){
                map.destroy();
                legendDijit.destroy();
                scalebar.destroy();
                overviewMapDijit.destroy();
              //Create <div> as the legend container
              domConstruct.create("div",{id:"legend"},"legendPanel", "first");
              //Create new map
              switch (mySelect.value){
                case "Chicago Youth Population":
                  youth();
                  break;
                case "USA Median Household Income":
                  median();
                  break;
                case "USA HHS Healthcare Resources":
                  health();
                  break;
              } // end switch
            } // end updateMap
            function dynamicMap(){
               map = new Map("map", {
                basemap: "topo",  //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
                center: [-98.5795, 39.8282], // longitude, latitude
                zoom: 4
              }); // end map
                var newLayer = new ArcGISDynamicMapServiceLayer("http://maps3.arcgisonline.com/ArcGIS/rest/services/A-16/HHS_IOM_Health_Resources/MapServer");
                map.addLayer (newLayer);
                legendLayers = [];
                if("legend" != undefined)
              constDiv (domConstruct, dom, on)
                legendLayers.push({layer: newLayer});
                legend = new Legend({
                map: map,
                layerInfos: legendLayers
                },"legend");
                legend.startup();
                scalebar = new Scalebar({
                 map: map,
                 scalebarUnit: "english"
                overviewMapDijit = new OverviewMap({
                 map: map,
                 visible: true
                overviewMapDijit.startup();
            function youth()  {
              arcgisUtils.createMap("c63cdcbbba034b62a2f3becac021b0a8","map").then(function(response){
          //update the app
          dom.byId("title").innerHTML = response.itemInfo.item.title;
          dom.byId("subtitle").innerHTML = response.itemInfo.item.snippet;
          map = response.map;
          //add the scalebar
            map: map,
          map: map,
          visible: true
          //add the legend. Note that we use the utility method getLegendLayers to get
          //the layers to display in the legend from the createMap response.
          var legendLayers = arcgisUtils.getLegendLayers(response);
          legendDijit = new Legend({
            map: map,
          },"legend");
          legendDijit.startup();
        }); // end map
            } // end youth
            function median()  {
              arcgisUtils.createMap("b4db98c3e1fe45c0afb7217f78b20d76","map").then(function(response){
          //update the app
          map = response.map;
          //add the scalebar
            map: map,
          map: map,
          visible: true
            map: map,
          },"legend");
        }); // end map
            } // end median
          function health()  {
            dynamicMap({
              map: map,
              visible: true
            dynamicMap.startup();
            } // end health
          // update map on first load
          updateMap();
          }) // end ready
      }); // end require
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'sidebar'" style="width:100%; height:100%;">
      <div id="header" class="shadow roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="width:100%; height:40px;">
        <div id="title"></div>
        <div id="subtitle"></div>
      </div>
      <div id="tabs" data-dojo-type="dijit/layout/TabContainer" data-dojo-props="region:'leading'" style="width: 20%; height: 100%; margin: 0px;">
                <div data-dojo-type="dijit/layout/ContentPane" title="Map Selection">Select the map from the drop-down list
                    <select method="get" data-dojo-type="dijit/form/ComboBox" id="mySelect" style="width: 100%">
                        <option value="Chicago Youth Population">Chicago Youth Population</option>
                        <option value="USA Median Household Income">USA Median Household Income</option>
                        <option value="USA HHS Healthcare Resources">USA HHS Healthcare Resources</option>
                    </select>
                </div>
                <div id="legendPanel" data-dojo-type="dijit/layout/ContentPane" title="Map Legend">
                    <div id="legend"></div>
                </div>
            </div>
      <div id="map" class="roundedCorners shadow" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
    </div>
  </body>
</html>
Thanks in advance
RobertScheitlin__GISP
Richard,
  I have made some corrections to your code and it work fine now (corrections commented):
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <style>
    html,
    body,
    #map {
      height: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    require([
        "dojo/on",
        "dojo/parser",
        "dojo/ready",
        "dojo/dom",
        "esri/map",
        "esri/urlUtils",
        "dojo/domReady!"
      ], function (
      on,
      parser,
      ready,
      BorderContainer,
      TabContainer,
      ContentPane,
      ComboBox,
      dom,
      domConstruct,
      Map,
      urlUtils,
      arcgisUtils,
      Legend,
      Scalebar,
      OverviewMap
      ready(function () {
          parser.parse();
          select.on('change', function (evt) {
            updateMap();
          }); // end on
            var selection;
            if (map != undefined) {
              map.destroy();
              scalebar.destroy();
            domConstruct.create("div", {
            }, "legendPanel", "first");
            //Create new map
            switch (mySelect.value) {
              youth();
              break;
              median();
              break;
              health();
              break;
            } // end switch
          } // end updateMap
          function dynamicMap() {
              zoom: 4
            }); // end map
            map.addLayer(newLayer);
            legendLayers = [];
            //Not sure why you are asking a string if it is undefined when you are defining it right there in the same line.
            //You do not have a constDiv function...
            /*if("legend" != undefined)
            legendLayers.push({
              layer: newLayer
              map: map,
            }, "legend");
            legend.startup();
              map: map,
              map: map,
              visible: true
          function youth() {
            arcgisUtils.createMap("c63cdcbbba034b62a2f3becac021b0a8", "map").then(function (response) {
              //update the app
              map = response.map;
              //add the scalebar
                map: map,
                map: map,
                visible: true
                map: map,
              }, "legend");
            }); // end map
          } // end youth
          function median() {
            arcgisUtils.createMap("b4db98c3e1fe45c0afb7217f78b20d76", "map").then(function (response) {
              //update the app
              map = response.map;
              //add the scalebar
                map: map,
                map: map,
                visible: true
                map: map,
              }, "legend");
            }); // end map
          } // end median
          function health() {
            dynamicMap();
            //Not sure way you were treating the dynamicMap function like a dijit with a constructor.
            /*dynamicMap({
              map: map,
              visible: true
            dynamicMap.startup();*/
          } // end health
          updateMap();
        }) // end ready
    }); // end require
  </script>
</head>
    </div>
        </select>
      </div>
      </div>
    </div>
  </div>
</body>
</html>
RichardLafleur
I know this is asking a lot and time is not on everyones side, but i need this by 5:45 tonight March 21, 2016
MichaelVolz
Esteemed Contributor
What kind of layers are the other two maps created from?
What sample did you use to get the following code snippet from?
RichardLafleur
The first two maps I used the web map IDs so the layers are already included, and the code came from an example in the arcgis Api. As for the third map i need to use the ArcGISDynamicMapServiceLayer ontop of a topo map
Richard,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #map {
      height: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    require([
        "dojo/on",
        "dojo/parser",
        "dojo/ready",
        "dojo/dom",
        "esri/map",
        "esri/urlUtils",
        "dojo/domReady!"
      ], function (
      on,
      parser,
      ready,
      BorderContainer,
      TabContainer,
      ContentPane,
      ComboBox,
      dom,
      domConstruct,
      Map,
      urlUtils,
      arcgisUtils,
      Legend,
      Scalebar,
      OverviewMap
      ready(function () {
          parser.parse();
            updateMap();
          }); // end on
            var selection;
              map.destroy();
              scalebar.destroy();
            //Create new map
              youth();
              break;
              median();
              break;
              health();
              break;
            } // end switch
          } // end updateMap
              zoom: 4
            }); // end map
            legendLayers = [];
            legendLayers.push({
              layer: newLayer
              map: map,
            }, "legend");
            legend.startup();
              map: map,
              map: map,
              visible: true
          function youth() {
              //update the app
              map = response.map;
              //add the scalebar
                map: map,
                map: map,
                visible: true
                map: map,
              }, "legend");
            }); // end map
          } // end youth
          function median() {
              //update the app
              map = response.map;
              //add the scalebar
                map: map,
                map: map,
                visible: true
                map: map,
              }, "legend");
            }); // end map
          } // end median
          function health() {
            dynamicMap();
            /*dynamicMap({
              map: map,
              visible: true
          } // end health
          updateMap();
        }) // end ready
    }); // end require
  </script>
</head>
    </div>
        </select>
      </div>
      </div>
    </div>
  </div>
</body>
</html>
RichardLafleur
Thank you to everyone, that was perfect and after seeing what had to be changed i feel like an idiot. so simple of changes.
