Vertical coordinate system
4372
08-13-2015 08:49 AM
ChristianMorin
Hello,
                I have a question about the vertical coordinate system. I have a service that serves X,Y in Web Mercator (102100) but the Z is NAVD_1988_Foot_US (ArcGIS Server doesn’t seem to send the vcsWkid in the Json for the service). The SceneView renders it assuming meters, so it stretches the objects vertically.
                What is the proper way to specify the vertical coordinate system in 4.0 beta 1? The query task doesn’t seem to allow you to specify the out vertical coordinate system.
                Any help would be appreciated.
Cheers,
Christian.
Tags (1)
KristianEkenes
Specifying a vertical coordinate system isn't possible in 4.0 beta 1. All z-values are in meters. Defining vertical coordinate systems will be available in a later release of the API, but unfortunately it's not available in beta 1. You can try to work around the issue by converting your z-values to meters for now.
KristianEkenes
ChristianMorin
Thanks for the answer Kristian. By a later release, do you mean a subsequent beta release or a release after 4.0 (like 4.1).
KristianEkenes
I'm not sure exactly sure. That's why I was purposefully vague . If I could guess, I would say not in a beta release, but I'm really not sure about it. What I do know is that it will be worked in at some point, but it hasn't been heavily discussed yet. There are other capabilities that need to be in place first.
