Move the default ESRI world geocoder to the end of the list of sources for search
4621
08-19-2015 08:58 AM
JssrRR
I am trying to move the ESRI world geocoder  to the bottom of my list sources for the search function, I believe the it is the first one in the sources array by default (Esri World Locator), as mentioned by Kelly Hutchins's Blog  in this thread,
https://community.esri.com/message/517562#517562
I have added four sources to the search function and I want to change the order so that ESRI world geocoder shows up at the end,
I tried this changing the number in the array,
sources: [4], it did not work
Any help or suggestions will be great!
ChrisSmith7
Honored Contributor
I wasn't successful, either, trying to load the source (commented-out code), but I did just reverse the array to show it's possible:
multiple sources example - world geocoder at the end - JSFiddle
ChrisSmith7
Honored Contributor
Have a look at the following thread - Disable ESRI World Geocoder from Search Bar
I provided an example of how to remove the Esri World Geocoder - I believe you can just add the Esri world geocoder source at the end of the sources array and it should show-up in that order.
I'll see if I can put-together a jsfiddle...
JssrRR
     sources.push({
    geocoder: new Geocoder("https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Locators/ESRI_Geocode_USA/GeocodeServer"),
  singleLineFieldName: "Single Line Input",
  outFields: ["Addr_type"],
  name: "ESRI World Geocoder",
  autoComplete: true,
            maxResults: 6,
            maxSuggestions: 6,
  //locator.outSpatialReference = map.spatialReference;
  placeholder: "Find a place or address",
         //Set the sources above to the search widget
         s.set("sources", sources);
         s.startup();
I tried your suggestion, do I have it right?
because it is showing up in the drop down at the end of the list, but is not actually working.
Thanks.
ChrisSmith7
Honored Contributor
JssrRR
Chris,
Yes, that worked, thanks.
