Version 4.15 -> 4.16+ PopupTemplate error
2046
03-06-2023 06:09 PM
YimYean
Hello,
I'm looking at updating to the latest SDK version 4.26 but getting error with the popupTemplate.content property and found that it started in 4.16.  Is there something that I would need to change in 4.16 to fix that error?
In 4.15 no issue, the popup template loads.
Then with 4.16 it doesn't load the content, just the title.
-- Code to create the FeatureLayer and assign the popup template
var featureLayer = new FeatureLayer({
	url: searchLayerInfoList[i].url,
	layerId: searchLayerInfoList[i].id,
	// configure the feature layer to return all fields
	outFields: ["*"],
	popupTemplate: getPopupTemplate(displayTitle)
-- Creating the popup template.  Fails on the content retrieval in 4.16+
function getPopupTemplate(displayTitle) {
    var template = {
        title: displayTitle,
        //content: generateCustomContent,
        content: function (target) {
            var fields = [
                    "fieldName": "OBJECTID",
                    "label": "OBJECTID",
                    "visible": true
            return [{ type: "fields", fieldInfos: fields }];
        actions: [customZoomAction]
    template.overwriteActions = true;
    return template;
Best,
Yim
YimYean
Was able to re-use the popup template function example code and updated to return the content array to show that the issue is reproducible.  In below example it's using latest 4.26 SDK.
<html lang="en">
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1, maximum-scale=1,user-scalable=no"
    <title>
      PopupTemplate - use functions to set content | Sample | ArcGIS Maps SDK
      for JavaScript 4.26
    </title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.26/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.26/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      let populationChange;
      require(["esri/Map", "esri/views/MapView", "esri/layers/Layer"], (
        Map,
        MapView,
        Layer
        const map = new Map({
          basemap: "dark-gray-vector"
        // Create the MapView
        const view = new MapView({
          container: "viewDiv",
          map: map,
          zoom: 6,
          center: [-87, 34]
        Layer.fromPortalItem({
          portalItem: {
            // autocasts as new PortalItem()
        }).then((layer) => {
          // add the layer to the map
          map.add(layer);
          // Create a new popupTemplate for the layer and
          // format the numeric field values using the FieldInfoFormat properties. Call the custom populationChange()
          // function to calculate percent change for the county.
          const popupTemplate = {
            // autocasts as new PopupTemplate()
            title: "Population in {NAME}",
            outFields: ["*"],
            content: populationChange
          layer.popupTemplate = popupTemplate;
          function populationChange(feature) {
            var content = [{type:"fields", fieldInfos: [
                fieldName: "POP2010",
                format: {
                  digitSeparator: true,
                  places: 0
                fieldName: "POP10_SQMI",
                format: {
                  places: 2
                fieldName: "POP2013",
                format: {
                  places: 0
                fieldName: "POP13_SQMI",
                format: {
                  places: 2
            return content;
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
UndralBatsukh
Hi there,
It looks like you can no longer autocast the FieldsContent object. If you update your code to create and return a new instance of this class then the popup should/will work. I tested it quickly and in my test the following works.
  const template = {
    const fields = [{
      "fieldName": "Street",
      "label": "Street",
     let fieldsElement = new FieldsContent({
       fieldInfos: fields
     return [fieldsElement];
  return template;
YimYean
Hi @UndralBatsukh ,
I tried the update and the console error and popup no longer gives an error but the fields aren't loading.  Are you able to provide the full sample in case I'm missing anything.
From my full sample code above I made the following update.
              require(["esri/popup/content/FieldsContent", "esri/popup/FieldInfo"], (FieldsContent, FieldInfo) => {
                  let fieldInfo1 = new FieldInfo({
                      label: "POP 2010",
                      visible: true
                  let fieldInfo2 = new FieldInfo({
                      label: "POP 2013",
                      visible: true
                      fieldInfos: [fieldInfo1, fieldInfo2]
But the fields aren't displayed.
YimYean
Thanks, looks like my method of importing the required FiedsContent and FieldInfo didn't work when it was used within the populationChange function.  But once I moved it to the top as in your example that resolved the issue.
Thank you for your help 🙂
