Using FEMA rest end point
10359
15
12-13-2017 07:56 AM
jaykapalczynski
Honored Contributor
I am trying to add FEMA  map service
FEMA: Mapping Information Platform: NOPAGETAB_NFHLWMS
Index number 28 from above link.
I am doing this:
I know there is an scale of 50,000 but no matter my zoom it does not render in my map.  I dont see any errors associated with this in the console
Thoughts?
var FloodZonelayer = new FeatureLayer("https://hazards.fema.gov/gis/nfhl/rest/services/public/NFHL/MapServer/28", {
    mode: FeatureLayer.MODE_SNAPSHOT,
    visible: true
legendLayers.push({ layer: FloodZonelayer, title: 'Flood Zones' });
map.addLayers([FloodZonelayer]);
RobertScheitlin__GISP
Jay,
  No I am not. Which leads me to say it is a service issue still.
jaykapalczynski
Honored Contributor
hmmmm...wondering why their's is so responsive and I am grabbing the same Service and mine is slow and not rendering everything....chalk it up to who knows I guess?
Jay,
   They are rendering as an ArcGISDynamicMapServiceLayer and you are using a FeatureLayer which is receiving all the geometry and rendering on the client where the ArcGISDynamicMapServiceLayer is rendered on the server and just an image is returned to the client.
jaykapalczynski
Honored Contributor
I do this and get this error about the GET request
var imageParameters = new ImageParameters();
ImageParameters.format = "jpeg"; //set the image type to PNG24, note default is PNG8.
var FloodZonelayer = new ArcGISDynamicMapServiceLayer("https://hazards.fema.gov/gis/nfhl/rest/services/public/NFHL/MapServer/28", {
"opacity" : 0.5,
"imageParameters" : imageParameters
Jay,
 Well you had a couple of issues in your code:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>FeatureLayer</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.23/esri/css/esri.css">
<script src="https://js.arcgis.com/3.23/"></script>
<style>
html, body, #map {
  padding: 0;
  margin: 0;
  height: 100%;
  width: 100%;
</style>
<script>
require([
    "esri/map",
    "esri/layers/ArcGISDynamicMapServiceLayer",
    "esri/layers/ImageParameters",
    "dojo/domReady!"
  function(
    Map,
    ArcGISDynamicMapServiceLayer,
    ImageParameters
    var map = new Map("map", {
      basemap: "gray",
      center: [-82.44109, 35.6122],
      zoom: 17
    imageParameters.format = "PNG32"; //set the image type to PNG24, note default is PNG8.
    imageParameters.layerIds = [28];
    imageParameters.layerOption = ImageParameters.LAYER_OPTION_SHOW;
    var FloodZonelayer = new ArcGISDynamicMapServiceLayer("https://hazards.fema.gov/gis/nfhl/rest/services/public/NFHL/MapServer", {
      "opacity" : 0.5,
    map.addLayer(FloodZonelayer)
</script>
</head>
<body>
  <div id="map"></div>
</body>
</html>
jaykapalczynski
Honored Contributor
First off hate how this site kicks you out every couple minutes....anoying...
Great....I was missing some parameters....this works great....got all the speed i was missing and all the layers.
I was referencing these example and did see the other parameters
ArcGIS API for JavaScript Sandbox
