Use CodedValueDomain value in LayerSearchSource.suggestionTemplate
761
09-07-2021 09:20 AM
EthanBodin1
I am using the Search widget and would like to provide suggestions using a template with a couple of field values. One of the fields may have a coded value domain, and I would like to display the name of the CodedValue instead of the code, which is what shows up if I just enter the field name in the template.
new LayerSearchSource({
   suggestionTemplate: "<b>Field 1: {stringField}<b><br/>Field 2: {codedValueField}"
Is there some way to replace "codedValueField" and get the coded value description for the field?
KevinEscalera1
@EthanBodin1 were you able to find a way to get the display value for a field with coded value domains?
