url parameter popup, and measure widget
12865
25
06-11-2012 12:43 PM
JohnBowdre
I am trying to disable the url parameter popup while I am using the measure widget.  I am able to hide the window when I click the measure widget and when I double click to end, but DURING the measurement the url parameter popup keeps........well...........popping up.  Any help would be appreciated.  Here is the code below I have been working with from the Javascript sample section in resources.arcgis.com.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior
    of the samples on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"
    <title>Parcel Locator</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/esri/dijit/css/Popup.css">
    <style>
      html, body {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      .esriScalebar {
        padding: 20px 20px;
      #map {
        padding:0;
    </style>
    <script type="text/javascript">
      var djConfig = {
        parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
      dojo.require("esri.layers.FeatureLayer");
   dojo.require("esri.dijit.Measurement");
      dojo.require("esri.dijit.Popup");
      var map;
      var parcels;
      function init() {
        //apply a selection symbol that determines the symbology for selected features
        var sfs = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([111, 0, 255]), 2), new dojo.Color([111, 0, 255, 0.15]));
        var popup = new esri.dijit.Popup({
          fillSymbol: sfs
        }, dojo.create("div"));
        map = new esri.Map("map", {
          infoWindow: popup,
          slider: false
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/AssessorsBasemap/MapServer/");
        map.addLayer(basemap);
        //apply a popup template to the parcels layer to format popup info
        var popupTemplate = new esri.dijit.PopupTemplate({
          title: "{PARCELID}",
          fieldInfos: [{
            fieldName: "SITEADDRESS",
            label: 'Address:',
            visible: true
            fieldName: "OWNERNME1",
            label: "Owner:",
            visible: true
        //add the parcels layer to the map as a feature layer in selection mode we'll use this layer to query and display the selected parcels
        parcels = new esri.layers.FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/AssessorsBasemap/MapServer/1", {
          outFields: ["*"],
          infoTemplate: popupTemplate,
          mode: esri.layers.FeatureLayer.MODE_SELECTION
        parcels.setSelectionSymbol(sfs);
        //when users click on the map select the parcel using the map point and update the url parameter
        dojo.connect(map, 'onClick', function (e) {
          var query = new esri.tasks.Query();
          query.geometry = e.mapPoint;
          var deferred = parcels.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (selection) {
            //update the url param if a parcel was located
            if (selection.length > 0) {
              var parcelid = selection[0].attributes['PARCELID'];
              //Refresh the URL with the currently selected parcel
              if (typeof history.pushState !== 'undefined') {
                window.history.pushState(null, null, "?parcelid=" + selection[0].attributes.PARCELID);
          map.infoWindow.setFeatures([deferred]);
          map.infoWindow.show(e.mapPoint);
        dojo.connect(map, 'onLayersAddResult', function (result) {
          // Add a link into the InfoWindow Actions panel
          var emailLink = dojo.create("a", {
            "class": "action",
            "innerHTML": "Email Map",
            "href": "javascript:void(0);"
          }, dojo.query(".actionList", map.infoWindow.domNode)[0]);
          // Register a function to be called when the user clicks on
          // the above link
          dojo.connect(emailLink, "onclick", function (evt) {
            var feature = map.infoWindow.getSelectedFeature();
            var url = window.location;
            var emailLink = "mailto:?subject=Parcel Map of :" + feature.attributes.PARCELID + "&body=Check out this map: %0D%0A " + window.location;
            window.location.href = emailLink;
          //When users navigate through the history using the browser back/forward buttons select appropriate parcel
          //https://developer.mozilla.org/en/DOM/Manipulating_the_browser_history
          window.onpopstate = function (event) {
            var parcelid = getParcelFromUrl(document.location.href);
            if (parcelid) {
              selectParcel(parcelid);
            } else {
              parcels.clearSelection();
              map.infoWindow.hide();
          //if a parcelid is specified in url param select that feature
        map.addLayers([parcels]);
        dojo.connect(map, 'onLoad', function (theMap) {
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
      //extract the parcel id from the url
      function getParcelFromUrl(url) {
        var urlObject = esri.urlToObject(url);
        if (urlObject.query && urlObject.query.parcelid) {
          return urlObject.query.parcelid;
        } else {
          return null;
      //select parcel from the feature layer by creating a query to look for the input parcel id
      function selectParcel(parcelid) {
        if (parcelid) {
          query.where = "PARCELID = '" + parcelid + "'";
            var center = esri.graphicsExtent(selection).getCenter();
            var extHandler = dojo.connect(map, 'onExtentChange', function () {
              dojo.disconnect(extHandler);
              //zoom to the center then display the popup
              map.infoWindow.setFeatures(selection);
              map.infoWindow.show(center);
            map.centerAt(center);
function disablepopup() {
  <!--MEASUREMENT TOOLS-->
  var measurement = new esri.dijit.Measurement({
            map: map, onClick: disablepopup
          },dojo.byId('measurementDiv'));
    measurement.startup()
  <!--DEACTIVATES MEASUREMENT TOOLS AFTER MEASUREMENT-->
  dojo.connect(measurement, "onMeasureEnd", function(activeTool,geometry){
  this.setTool(activeTool, false), map.infoWindow.hide()
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
  <!--CENTER and RIGHT CONTAINER-->
  <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;">
   </div>
   <div id="bottomPane" dojotype="dijit.layout.ContentPane" region="bottom">
  <div id="bottomPane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Measurement Tools', closable:'false', open:'false'">
            <div id="measurementDiv"></div>
            <center><button dojoType="dijit.form.Button"  iconClass="eraserIcon" onclick="map.graphics.clear();">Clear Measurement</button></center>
          </div>
  </body>
</html>
Thanks!!
LisCollins
Hi Kelly,
I just noticed that the code to turn off popups when the measurement button is on messes up my code for printing. It's no longer working. I'm either getting a time out error, or depending on what computer I'm using, I get this error in Firefox:Loading mixed (insecure) display content on a secure page.
Any ideas?
Code for printer in main.js file:
//for PRINTER ***********************
   if (this.config.enablePrintButton) {       //if the printing function is enabled true
   this._printer = new Print({                      //create a new printer widget called this._printer
   map: this.map, //the map to print
   templates: [{
  label: "Layout",   format: "PDF",   layout: "A3 Landscape",   layoutOptions: {
titleText: "Map",
   url: "printing service URL here. just removed for now"//the url to export the web map task
   }, dom.byId("printButton"));   //html element where the print widget button/drop down will be rendered
   this._printer.startup();                 //finalize the creation of the widget
ChrisSergent
I'm not sure how busy Kelly Hutchins​ is, but she is presenting at the DevSummit this week. However, I imagine it would be helpful for her or someone else if you posted the complete modified code, which you can post here: JS Bin - Collaborative JavaScript Debugging  and then share that url. You also may want to consider starting a new thread. You can still tag Kelly by placing the @ symbol before her name if it doesn't appear in your list, you can type her name and just place an underscore where the space in her name is.
ChrisSergent
I had an application where the infoWindow and the editor widget conflicted. It's appears to be similar to your issue. Check out my post on how I resolved the conflict. You may need to destroy your measurement tool and bring it back and possibly create button to start identifying features:
Adding an Editor to the Template
StevenGraf1
Here's how I am disabling Identify while measuring.
on(measurement, "tool-change", function(){
          map.setInfoWindowOnClick(false);
  on(measurement, "measure-start", function(){
  on(measurement, "unit-change", function(){
        on(measurement, "measure-end", function(evt){
          //measurement.setTool("location", false);
          map.setInfoWindowOnClick(true);
The "unit-change" doesn't seem to work when the
showAdvancedUnits: true
constructor detail is on in ArcServer 10.3 though.
Hope this helps.
StephenPatterson1
I created my own Measure Widget and Annotation Widget with the version 4.5 API and am running into this same issue.  Is there a new way to disable popups with 4.0+ API when adding points with the SketchViewModel or Draw tool?
I was able to disable popups for polygons and lines by using a click event and calling event.stopPropagation() while my tools are active, but it won't let me draw points or multipoints because it is a click event.
The map.setInfoWindowOnClick() function from the 3.0 API does not seem to be in the latest API.
StephenPatterson1
I figured out another way around the issue.  Our application calls the map hit tests and identify tasks from one function, so I set a boolean property to true while someone is using the widgets and set it back to false when finished.  I check for that property now when the map click event happens, which bypasses the popups.
