url parameter popup, and measure widget
12867
25
06-11-2012 12:43 PM
JohnBowdre
I am trying to disable the url parameter popup while I am using the measure widget.  I am able to hide the window when I click the measure widget and when I double click to end, but DURING the measurement the url parameter popup keeps........well...........popping up.  Any help would be appreciated.  Here is the code below I have been working with from the Javascript sample section in resources.arcgis.com.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior
    of the samples on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"
    <title>Parcel Locator</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/esri/dijit/css/Popup.css">
    <style>
      html, body {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      .esriScalebar {
        padding: 20px 20px;
      #map {
        padding:0;
    </style>
    <script type="text/javascript">
      var djConfig = {
        parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
      dojo.require("esri.layers.FeatureLayer");
   dojo.require("esri.dijit.Measurement");
      dojo.require("esri.dijit.Popup");
      var map;
      var parcels;
      function init() {
        //apply a selection symbol that determines the symbology for selected features
        var sfs = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([111, 0, 255]), 2), new dojo.Color([111, 0, 255, 0.15]));
        var popup = new esri.dijit.Popup({
          fillSymbol: sfs
        }, dojo.create("div"));
        map = new esri.Map("map", {
          infoWindow: popup,
          slider: false
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/AssessorsBasemap/MapServer/");
        map.addLayer(basemap);
        //apply a popup template to the parcels layer to format popup info
        var popupTemplate = new esri.dijit.PopupTemplate({
          title: "{PARCELID}",
          fieldInfos: [{
            fieldName: "SITEADDRESS",
            label: 'Address:',
            visible: true
            fieldName: "OWNERNME1",
            label: "Owner:",
            visible: true
        //add the parcels layer to the map as a feature layer in selection mode we'll use this layer to query and display the selected parcels
        parcels = new esri.layers.FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/AssessorsBasemap/MapServer/1", {
          outFields: ["*"],
          infoTemplate: popupTemplate,
          mode: esri.layers.FeatureLayer.MODE_SELECTION
        parcels.setSelectionSymbol(sfs);
        //when users click on the map select the parcel using the map point and update the url parameter
        dojo.connect(map, 'onClick', function (e) {
          var query = new esri.tasks.Query();
          query.geometry = e.mapPoint;
          var deferred = parcels.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (selection) {
            //update the url param if a parcel was located
            if (selection.length > 0) {
              var parcelid = selection[0].attributes['PARCELID'];
              //Refresh the URL with the currently selected parcel
              if (typeof history.pushState !== 'undefined') {
                window.history.pushState(null, null, "?parcelid=" + selection[0].attributes.PARCELID);
          map.infoWindow.setFeatures([deferred]);
          map.infoWindow.show(e.mapPoint);
        dojo.connect(map, 'onLayersAddResult', function (result) {
          // Add a link into the InfoWindow Actions panel
          var emailLink = dojo.create("a", {
            "class": "action",
            "innerHTML": "Email Map",
            "href": "javascript:void(0);"
          }, dojo.query(".actionList", map.infoWindow.domNode)[0]);
          // Register a function to be called when the user clicks on
          // the above link
          dojo.connect(emailLink, "onclick", function (evt) {
            var feature = map.infoWindow.getSelectedFeature();
            var url = window.location;
            var emailLink = "mailto:?subject=Parcel Map of :" + feature.attributes.PARCELID + "&body=Check out this map: %0D%0A " + window.location;
            window.location.href = emailLink;
          //When users navigate through the history using the browser back/forward buttons select appropriate parcel
          //https://developer.mozilla.org/en/DOM/Manipulating_the_browser_history
          window.onpopstate = function (event) {
            var parcelid = getParcelFromUrl(document.location.href);
            if (parcelid) {
              selectParcel(parcelid);
            } else {
              parcels.clearSelection();
              map.infoWindow.hide();
          //if a parcelid is specified in url param select that feature
        map.addLayers([parcels]);
        dojo.connect(map, 'onLoad', function (theMap) {
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
      //extract the parcel id from the url
      function getParcelFromUrl(url) {
        var urlObject = esri.urlToObject(url);
        if (urlObject.query && urlObject.query.parcelid) {
          return urlObject.query.parcelid;
        } else {
          return null;
      //select parcel from the feature layer by creating a query to look for the input parcel id
      function selectParcel(parcelid) {
        if (parcelid) {
          query.where = "PARCELID = '" + parcelid + "'";
            var center = esri.graphicsExtent(selection).getCenter();
            var extHandler = dojo.connect(map, 'onExtentChange', function () {
              dojo.disconnect(extHandler);
              //zoom to the center then display the popup
              map.infoWindow.setFeatures(selection);
              map.infoWindow.show(center);
            map.centerAt(center);
function disablepopup() {
  <!--MEASUREMENT TOOLS-->
  var measurement = new esri.dijit.Measurement({
            map: map, onClick: disablepopup
          },dojo.byId('measurementDiv'));
    measurement.startup()
  <!--DEACTIVATES MEASUREMENT TOOLS AFTER MEASUREMENT-->
  dojo.connect(measurement, "onMeasureEnd", function(activeTool,geometry){
  this.setTool(activeTool, false), map.infoWindow.hide()
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
  <!--CENTER and RIGHT CONTAINER-->
  <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;">
   </div>
   <div id="bottomPane" dojotype="dijit.layout.ContentPane" region="bottom">
  <div id="bottomPane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Measurement Tools', closable:'false', open:'false'">
            <div id="measurementDiv"></div>
            <center><button dojoType="dijit.form.Button"  iconClass="eraserIcon" onclick="map.graphics.clear();">Clear Measurement</button></center>
          </div>
  </body>
</html>
Thanks!!
ChrisSergent
There are three buttons already in the widget. The first one has the following ID: widgetid="dijit_form_ToggleButton_0   You could disable the identify based on the click event of each of these buttons, the first of the three being - dijit_form_ToggleButton_0. If the esriButtonChecked class exists, disable identify, otherwise enable identify.
Here is an example on how to evaluate class name: HTML DOM className Property
The reason I said to evaluate class of esriButtonChecked is that, that class appeared when I clicked on dijit_form_ToggleButton_0 and then disappeared when I deselected it. This method would allow you to avoid adding buttons.
KellyHutchins
Esri Notable Contributor
Lis,
Something like this should work where you deactivate the popups every time someone activates a tool on the measure widget.  In order for the code below to work you'll need to load the dojo/on and dojo/query modules.
        query(".esriMeasurementButtonPane .esriButton").on("click", function(c){
          var tool = measurement.getTool();
          if(tool){
            //deactivate the popup window
            map.setInfoWindowOnClick(false);
          }else{
            //activate the popup window
            map.setInfoWindowOnClick(true);
Here's a jsbin showing this in action:
Measure Tool
ChrisSergent
Kelly,
Just wanted to make sure I understand this. I have a project that I will need to add this functionality into later.
In this line;  query(".esriMeasurementButtonPane .esriButton").on("click", function(c){
Is it correct to say that you are querying the classes of .esriMeasurementButtonPane .esriButton as a listener for a click event after which you evaluate the tool which if it has that method, could be any tool? If it were a different tool, how do I know which classes I want to query? Is it always the pane and the button?
Last, what purpose does the c have in the function; it's an argument, but it does not appear to be used. Is it needed?
KellyHutchins
Chris Sergent
In the code snippet above I use dojo/query to find the measurement widget buttons based on the esri classes. If I inspect the Measure tools with the Chrome Dev Tools I can see that they have an esriButton class applied so I query for any buttons on the measurement widget and associate a click event handler with them. That way anytime someone clicks on one of the buttons I can check and see if there is an active tool. I do this using measurement.getTool. If no tool is selected then measurement.getTool returns undefined. If there is an active tool then I disable the popup.
c is just the name I gave to the event arg - we don't need them for this logic so you could leave that out.
ChrisSergent
Kelly Hutchins
Okay, so the final item; would the .esriMeasurementPane be included in the query to ensure that the .esriButton(s) are within that class, so other buttons in other controls are not affected?
KellyHutchins
Correct.
ChrisSergent
Thanks. I added the information to my notes for future reference. I've been reading the API Reference along with the examples lately or posters questions. It's helped out a lot. It makes a difference when I am trying to figure what functionality different items have.
LisCollins
I get this error when I press one of my measurement buttons:
Uncaught TypeError: Cannot read property 'setInfoWindowOnClick' of undefinedmain.js:442 (anonymous function)init.js:1492 n.__onClickinit.js:177 (anonymous function)
I already added the query and on modules too.
This is what I have after measurement startup in my public information template main.js page:
          var map = this.map;
          if(tool){
          }else{
KellyHutchins
I suspect that your map variable is not defined. Try setting a breakpoint in your code at the line where you set map equal to this.map and see if the this.map value is defined.
You can set breakpoints using browser developer tools. For example if you are using Chrome here's how you'd set a breakpoint:
https://developer.chrome.com/devtools/docs/javascript-debugging#breakpoints
Or write the value to the console using console.log(this.map) then check the developer console and see if the value for map is defined.
If the value is not defined you'll need to use lang.hitch in order to retain the scope. Here's how that would look.
  query(".esriMeasurementButtonPane .esriButton").on("click", lang.hitch(this, function(c){
          var map = this.map;
          if(tool){
          }else{
LisCollins
It worked!
Thanks so much!
I always wondered what lang.hitch was used for. I have a lot to learn.
