upgrading to 4.25, dojo/query and esri/rest/query are conflicting
3390
6
01-12-2023 11:59 AM
JayHill
I am upgrading an older web map from 4.17 to 4.25 and don't have the time to rebuild with ES modules. I'm looking for a way to call dojo/query and esri/rest/query by different names using AMD modules.
Uncaught TypeError: query.executeQueryJSON is not a function
This error popped up after upgrading to 4.25 where the dojo library is no longed included with the CDN package.  Assuming this is the reason because 4.24 still works.
2 Solutions
MichaelSnook
Gotcha...I should have read slower...I have both in projects and I have the dojo/Query init function parameter set to 'query', and have the esri/rest/query parameter set to 'restQuery' -- then calling restQuery.executeQueryJSON works fine.
MichaelSnook
Sure...
require([
        "esri/rest/query",
        "dojo/query"
    ], function (
            restQuery,
            query
	//esri restQuery call
	restQuery.executeQueryJSON(){
MichaelSnook
You can still pull dojo in via the dojoConfig a 4.25+...
See here:
https://developers.arcgis.com/javascript/latest/release-notes/#removal-of-non-esri-packages-from-cdn
packages: [
JayHill
Right, I am pulling it from another CDN but I get "Uncaught TypeError: query.executeQueryJSON is not a function" error and I am assuming my code is confusing dojo/query and esri/rest/query as I use both for the app.
MichaelSnook
JayHill
Thanks @MichaelSnook would you have an example of the code?
MichaelSnook
Sure...
require([
        "esri/rest/query",
        "dojo/query"
    ], function (
            restQuery,
            query
JayHill
Ah I see. So simple. Thanks!
