ArcGIS Maps SDK for JavaScript example: Previous and Next extent buttons (updated for 4.25)
2390
01-12-2023 01:35 PM
Egge-Jan_Pollé
I like to have my Previous extent and Next extent buttons in a web mapping application. Don't you?
ArcGIS Maps SDK for JavaScript example: Previous and Next extent buttonsArcGIS Maps SDK for JavaScript example: Previous and Next extent buttonsBut as far as I know the (new) ArcGIS Maps SDK for JavaScript does not have a default widget for that. Is that correct?
So, I have created an example with my own Previous and Next Buttons - see sample code below or click on the map to get to a working application.
True, my version of these buttons owes a lot to work done by @RobertScheitlin__GISP (see his app with a navigation toolbar in this post.)
I have updated the code for the two buttons to 4.25, removing dojo and replacing watchUtils with reactiveUtils.
And I managed to group the two buttons together (like the zoom in and zoom out buttons) using esri css classes.
I think it all works, more or less. Can you please test it and tell me what you think?
Cheers,
Egge-Jan
TWIAV | ArcGIS JavaScript example - Previous and Next extent buttons
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>TWIAV | ArcGIS JavaScript example - Previous and Next extent buttons</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.25/esri/css/main.css">
  <script src="https://js.arcgis.com/4.25/"></script>
  <style>
    html, body {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      font-family: sans-serif;
    #header {
    	width: 100%;
        height: 70px;
        background-color: #154273;
        color:#FFFFFF;
        margin: 0;
    #headertext {
        float: left;
        font-size: 35px;
        color: white;
        line-height: 70px;
        padding-left: 15px;
    #viewDiv {
        position: absolute;
        top: 70px;
        bottom: 0;
        right: 0;
        left: 0;
        padding: 0;
        margin: 0;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
	  "esri/core/reactiveUtils"
    ], function(Map, MapView, reactiveUtils) {
      var map = new Map({
        basemap: "osm"
      var view = new MapView({
        container: "viewDiv",
        map: map,
        zoom: 10,
        center: [0, 51.5]
      createZoomPrevZoomNextBtns();
      view.ui.add(["zoomPrevNextBtns"], "top-left");
       * Start Zoom Previous and Zoom Next buttons
	   * The solution presented here to add these 2 zoom buttons is based on work by RobertScheitlin__GISP.
	   * See his answer to this question:
	   * https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/does-the-class-quot-esri-toolbars-navigation-quot/m-p/567061
	   * Changes to the original RobertScheitlin__GISP solution: removed dojo and replaced watchUtils with reactiveUtils (to upgrade to 4.25)
      _prevExtent = false;
      _preExtent = null;
      _currentExtent = null;
      _extentHistory = [];
      _extentHistoryIndx = 0;
      _nextExtent = false;
      reactiveUtils.when(
        () => view.stationary === true,
          extentChangeHandler(view.extent);
      function createZoomPrevZoomNextBtns() {
        const zoomPrevNextBtnsDiv = document.createElement('div');
		zoomPrevNextBtnsDiv.innerHTML = `
		  <div id="zoomPrevNextBtns" class="esri-component esri-zoom">
		    <div id="zoomPrevBtn" class="esri-widget--button esri-widget esri-disabled" role="button">
              <span title="Previous extent" id="zoomPrev" class="esri-icon esri-icon-left-arrow-circled"></span>
            </div>
		    <div id="zoomNextBtn" class="esri-widget--button esri-widget esri-disabled" role="button">
              <span title="Next extent" id="zoomNext" class="esri-icon esri-icon-right-arrow-circled"></span>
            </div>
          </div>`;
        document.body.appendChild(zoomPrevNextBtnsDiv);
      let l_zoomPrevBtn = document.getElementById("zoomPrevBtn");
	  l_zoomPrevBtn.addEventListener("click", zoomPreviousExtent);
      let l_zoomNextBtn = document.getElementById("zoomNextBtn");
	  l_zoomNextBtn.addEventListener("click", zoomNextExtent);
      function zoomNextExtent() {
        _nextExtent = true;
        _extentHistoryIndx++;
        if (_extentHistoryIndx > _extentHistory.length - 1) { // this might happen if the user clicks the zoomNext button too often too fast
          _extentHistoryIndx = _extentHistory.length - 1;
        view.goTo(_extentHistory[_extentHistoryIndx].currentExtent);
		function zoomPreviousExtent() {
        if(_extentHistory[_extentHistoryIndx].preExtent){
          _prevExtent = true;
          view.goTo(_extentHistory[_extentHistoryIndx].preExtent);
          _extentHistoryIndx--;
      function extentChangeHandler(evt) {
        if(_prevExtent || _nextExtent){
          _currentExtent = evt;
        }else{
          _preExtent = _currentExtent;
          _extentHistory.push({
            preExtent: _preExtent,
            currentExtent: _currentExtent
        _prevExtent = _nextExtent = false;
        extentHistoryChange();
      function extentHistoryChange() {
        if(_extentHistory.length === 0 || _extentHistoryIndx === 0 ){
		  l_zoomPrevBtn.classList.add("esri-disabled");
        } else {
		  l_zoomPrevBtn.classList.remove("esri-disabled");
        if(_extentHistory.length === 0 || _extentHistoryIndx === _extentHistory.length - 1){
		  l_zoomNextBtn.classList.add("esri-disabled");
        } else {
		  l_zoomNextBtn.classList.remove("esri-disabled");
       * End Zoom Previous and Zoom Next buttons
  </script>
</head>
<body>
  <div id="header">
      <div id="headertext" class="stretch">ArcGIS Maps SDK for JavaScript example: Previous and Next extent buttons</div>
  </div>
  <div id="viewDiv"></div>
</body>
</html>
