Unusual Problem with Print Widget
2952
10
05-09-2013 12:00 PM
DanielTrone
I have a small problem in my code, but it is resulting in a big headache.
I am using the Print Widget (w/ a proxy).  If you press the button once, a couple of errors are thrown (in Firebug), and the process fails.  However, the next time the button is pressed (and forever after), it works.
Interestingly enough, if you don't select a layer in the dropdown, the print process will work the first time.
I have stripped down the code to the bare minimum to illustrate the problem.  I would be thankful for any suggestions.
http://jsfiddle.net/DanielTrone/zjNjx/
JohnGravois
rock and roll.  im glad to hear we got you sorted out.
