Unable to use the sample Edit without editor widget
4170
11
01-08-2013 08:19 PM
ouyajam
I'm trying to run the sample "Edit without editor widget" on my computer. But all the edits I made simply can not apply to the featurelayer. However the online live sample is able to apply every edit. Can anybody tell me why?Thanks a lot!
KellyHutchins
Esri Notable Contributor
You probably need to setup a proxy page. Instructions on how to do so are here:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/ags_proxy.htm
Once you've setup the proxy modify the following line in the code to point to the location of your proxy.
    esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
AdrianMarsden
Honored Contributor
Hi - I've got a similar issue - but it seems to be IE specific.  I have the proxy all set and Chrome and Firefox work fine./  Yet IE (8 & 9) fail
In Fiddler I see a 500 error reported for
POST /proxy/proxy.ashx?http://our server/arcgis/rest/services/test/edit/FeatureServer/0//applyEdits HTTP/1.1
With the page being returned as the normal .NET page
Server Error in '/proxy' Application.  and saying how to make changes to the web.config (which I don't have) to get better errors.
I've just used the default proxy pages from the esri site (I'd edited the previous ones) and still get the error.
When run on the server - fiddler shows a 500 page with
[TABLE="width: 100%"]
[No relevant source lines]
[/TABLE]
Any ideas.
ACM
KellyHutchins
When I first setup a proxy I usually set the following value in the proxy.config file to false. This will proxy any site which is good for testing.
<ProxyConfig mustMatch="false">
After verifying that the proxy works using the above setting you can set it back to true then use the <serverUrl> tags to specify the URL of the sites that should be proxied.
AdrianMarsden
Honored Contributor
Si instead of
   <serverUrl url="http://hummer/ArcGIS/rest/services"               matchAll="true"
               dynamicToken="true"
               ></serverUrl>
Would you simply have
   <serverUrl                matchAll="flase"
               dynamicToken="true"
               ></serverUrl>
?  The comments in the proxy.config isn't very clear.  To me " matchAll = true to forward any request beginning with the url"
Means that if I set the URL to "http://myserver/" and matchAll = True the any request beginning "http://myserver/" will work.
Cheers
ACM
AdrianMarsden
Honored Contributor
Sorry - misread your post - see the setting you mean now.  I'll try that.
KellyHutchins
Insted of the matchAll attribute for the serverUrl tags look at the top of the proxy.config file and you should see a <ProxyConfig> tag. This tag has a mustMatch attribute. If you set it to false it will proxy everything which is great for testing to see if your proxy works.
<?xml version="1.0" encoding="utf-8" ?>
<!-- Proxy config is used to set the ArcGIS Server services that the proxy will forward to.
        mustMatch: true to only proxy to sites listed, false to proxy to any site -->
  <serverUrls>
    <!-- serverUrl options:
            url = location of the ArcGIS Server, either specific URL or stem
            token = (optional) token to include for secured service
            dynamicToken = if true, gets token dynamically with username and
              password stored in web.config file's appSettings section.
    <serverUrl url="http://sampleserver1.arcgisonline.com/arcgis/rest/services/"
               matchAll="true"></serverUrl>
    <serverUrl url="http://sampleserver2.arcgisonline.com/arcgis/rest/services/"
               matchAll="true"
               token=""></serverUrl>
    <serverUrl url="http://server.arcgisonline.com/arcgis/rest/services/"
  </serverUrls>
</ProxyConfig>
BayNgo
Hi Kelly!
I set proxy.config:
    <serverUrls>
        <serverUrl url="http://<myservername>/arcgis/rest/services/"
               matchAll="true"/>
    </serverUrls>
</ProxyConfig>
and I put folder "dotnet" (consist of: proxy.ashx, proxy.config, web.config) to: C:\inetpub\wwwroot
then my code in web app is:
esriConfig.defaults.io.proxyUrl ="http://<myservername>/dotnet/proxy.ashx";
I tested this link: http://<myservername>/dotnet/proxy.ashx?http://<myservername>/ArcGIS/rest/services/map/sde_commune/M...  with no error, but all the edits I made can not apply to my featurelayer.
Please help me, thanks!
AdrianMarsden
Honored Contributor
Thanks for that - we posted at the same time - however, my proxy.config  now looks like this and IE still fails
  <serverUrls>
    <serverUrl url="http://eddc-gis2"
               matchAll="true"
               ></serverUrl>
  </serverUrls>
</ProxyConfig>
I'll see if I get get a page on the internet later.
IE just does nothing.
Cheers
ACM
KellyHutchins
Did you follow the steps in the ASP.net section in the help to setup your proxy in IIS?
http://help.arcgis.com/en/webapi/javascript/arcgis/jshelp/#ags_proxy
