TypeScript 1.6 Support for ES6
1925
10-02-2015 10:17 AM
MarkCederholm
Regular Contributor II
Is it possible to use the existing type definitions on GitHub to compile to ECMAScript 6 using TypeScript 1.6?  If I try the following:
import * as esriMap from "esri/map";
I get the error: Module "esri/map" resolves to a non-module entity
Or are there plans to build an ES6-compatible version of the type definitions?
MarkCederholm
It turns out that the edits to the definitions are pretty simple.  I've attached the resulting file.
