Tooltips not changing
1875
01-22-2014 06:34 AM
AleydisG__Pere
I've tried setting esri.bundle.toolbars.draw.addPoint and esri.bundle.toolbars.draw.freehand but my drawing tools keep showing the default tooltip.
When I type console.dir(esri.bundle) in my browser's console they actually have changed to the strings I set though.
Any idea of what is going on?
JamieSimko
Are you setting the tooltips before activating the drawTool?
A code snippet where you setup the map and draw tool would help answer your question if setting the tooltips and then calling drawTool.activate() doesn't work.
JonathanUihlein
Agree with Jsim. His answer is correct.
Using this sample:
https://developers.arcgis.com/en/javascript/jssamples/graphics_add.html
        function initToolbar() {
          tb = new Draw(map);
          esri.bundle.toolbars.draw.freehand = "new label";
          tb.on("draw-end", addGraphic);
          // event delegation so a click handler is not
          // needed for each individual button
          on(dom.byId("info"), "click", function(evt) {
            if ( evt.target.id === "info" ) {
              return;
            var tool = evt.target.id.toLowerCase();
            map.disableMapNavigation();
            tb.activate(tool);
jsfiddle:
http://jsfiddle.net/7KjX8/
AleydisG__Pere
The source of the problem is the locate I'm using (ca_ES). The ArcGIs JS API doesn't support the catalan language. When commenting out the locale setting in dojoConfig it works.
Acording to the documentation I should create a new resource bundle file for my language.
Is there any sample file to start with? I'm checking the online documentation. Hope I find something.
BTW, checking that jsfiddle helped me realize what was the problem. Thanks!
JonathanUihlein
Great! Glad to help 😃
Feel free to make another thread if you have any issues with internationalization.
Lastly, please mark this thread as 'answered' if you are completely satisfied with the responses received thus far.
