Tolerance point selection question
2461
08-25-2014 12:34 PM
PaulWilner_II
Hi all:
Below you'll see my code with a lot of placeholders currently, however I'm trying to select a point feature layer on click. All seems to work well outside of my layout,  scheme, however when I apply my layout via css and html  the selection seems to be  way off(like selecting things far away from the click if at all)
Thanks in advance for help.
<Code>
<!DOCTYPE html>
<html >
<head>
  <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">
  <style type ="text/css">html, body {
    height:100%;
    margin-top: 2%;
}</style>
  <script>dojoConfig = {async: true, parseOnLoad: true}</script>
  <script src="http://js.arcgis.com/3.9/"></script>
  <script>
require([
    "esri/map",
    "dojo/dom", // for inserting value in TextBox example
    "dojo/parser", // parser because of TextBox decoration
    "dijit/form/HorizontalSlider",
    "dijit/form/TextBox",
    "dijit/form/HorizontalRule",
    "dijit/form/HorizontalRuleLabels",
    "dijit/TitlePane",
    "dijit/layout/AccordionContainer",
    "dijit/layout/AccordionPane",
    "dijit/layout/ContentPane",
    "dijit/layout/BorderContainer",
    "dijit/layout/TabContainer",
    "esri/dijit/Legend",
    "esri/layers/FeatureLayer",
    "esri/symbols/SimpleMarkerSymbol",
    "esri/InfoTemplate",
    "esri/tasks/QueryTask",
    "esri/tasks/query",
    "esri/geometry/Point",
    "esri/geometry/Extent",
    "dojo/domReady!"
    // this we only include to make an example with TextBox
], function(Map,
  dom,
  parser,
  HorizontalSlider,
  TextBox,
  HorizontalRule,
  HorizontalRuleLabels,
  TitlePane,
  AccordianContainer,
  AccordianPane,
  ContentPane,
  BorderContainer,TabContainer,Legend,FeatureLayer,SimpleMarkerSymbol,InfoTemplate,QueryTask,Query,Point,Extent){
//INITIALIZE MAP
var map;
        map = new Map("map", {
          basemap: "gray",
          center:[-75.148, 42.706], //long, lat
          zoom: 7
//FUNCTIONALITY CODE STARTS HERE
      var infoTemplate = new InfoTemplate();
      infoTemplate.setTitle(("${CAMPUSNAME}"));
      infoTemplate.setContent("${CAMPUSNAME}");
//var SUNYSchools = new FeatureLayer("http://scentgis1.sysadmin.suny.edu:6080/arcgis/rest/services/tstServiceFolder/Mapof64/MapServer/0", {
//mode: FeatureLayer.MODE_SNAPSHOT,
     //     outFields: ["*"],
//         infoTemplate: infoTemplate
//map.addLayer(SUNYSchools);
var SUNYSchools2 = new FeatureLayer("http://scentgis1.sysadmin.suny.edu:6080/arcgis/rest/services/tstServiceFolder/Mapof64/FeatureServer/...", {
          outFields: ["CAMPUSNAME"],
map.addLayers([SUNYSchools2]);
var selectionSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE);
SUNYSchools2.setSelectionSymbol(selectionSymbol);
map.on("click",function calcTol(evt) {
        var selectionQuery = new esri.tasks.Query();
        var tol = map.extent.getWidth()/map.width * 5;
        var x = evt.mapPoint.x;
        var y = evt.mapPoint.y;
        var queryExtent = new esri.geometry.Extent(x-tol,y-tol,x+tol,y+tol,evt.mapPoint.spatialReference);
        selectionQuery.geometry = queryExtent;
        SUNYSchools2.selectFeatures(selectionQuery,esri.layers.FeatureLayer.SELECTION_NEW);
        console.log(selectionQuery.geometry);
//var selectQuery=new Query();
//map.on("click",function(evt){
  //selectQuery.geometry=pointToExtent(map,evt.mapPoint,10);
  //SUNYSchools2.selectFeatures(selectQuery,FeatureLayer.SELECTION_NEW,function(features){
  //console.log(selectQuery.geometry);
//console.log(features.length);
//Layout Stuff starts here
var legend = new Legend({
    map: map,
    layerInfos : [ {
            layer:SUNYSchools2,
            title : 'SUNY Campuses'
  }, "legenddiv");
  legend.startup();
    var x;
    var slider = new HorizontalSlider({
        value: 2011,
        minimum: 2011,
        maximum: 2014,
        intermediateChanges: true,
        discreteValues:4,
        style: "width:100%;",
        showButtons: false,
        onChange: function(value){
        x = value;
        if (x== 2014)
      alert("Happy New Year!");
    console.log(x);
    }, "slider").startup();
    var aContainer = new AccordianContainer("markup");
    var tp = new TitlePane({title:"Tools", content: "markup"});
    dom.byId("holder").appendChild(tp.domNode);
    tp.startup();
  </script>
sunyheader
</head>
<body class="claro">
  <div id ="holder"></div>
      <div data-dojo-type="dijit/layout/BorderContainer" style="width: 100%; height: 100%">
     <div id = "legends"div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style = "width:200px">
             <div id ="legenddiv" style = "width:200px"></div>
       </div>
     <div id ="map" div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style= "height:100%"></div>
     <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'trailing'">Trailing pane</div>
     <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" ><div id="slider">
    <div data-dojo-type="dijit/form/HorizontalRule" container="bottomDecoration"
        count=4 style="height:5px;"></div>
    <ol data-dojo-type="dijit/form/HorizontalRuleLabels" container="bottomDecoration"
        style="height:1em;font-size:75%;color:gray;">
        <li>2011</li>
        <li>2012</li>
        <li>2013</li>
        <li>2014</li>
    </ol>
</div></div>
</div>
</body>
<footer>
  <p>Posted by: Hege Refsnes</p>
  <p>Contact information: <a href="mailto:[email protected]">
  [email protected]</a>.</p>
</footer>
</html>
</code>
KenBuja
MVP Esteemed Contributor
This can usually be solved by applying a resize to the map once it's loaded.
map.on("load", function(){
   map.resize();
KenBuja
   map.resize();
PaulWilner_II
Looks like this is working! Thank you so much. It is the simple things most times that trip me up!
KenBuja
Glad to help. I use the code from this post in my projects now.
var resizeTimer;
map.on("load", function () {
  registry.byId("divMap").on("resize", function () {
    clearTimeout(resizeTimer);
    resizeTimer = setTimeout(function () {
      map.resize();
      map.reposition();
    }, 500);
