toggling function on and off
1099
06-29-2012 08:35 AM
ChrisBerryman1
I am trying to write a function that will allow me to turn a function off with a checkbox.
here is my code:
jQuery("#centeronCurrentLocationCheckBox").change(function() {
  if(showLocation == 0){
    showLocation = 1;
   }else{
    showLocation = 0;
   alert("hi");
I have another working checkbox that does the same as this, so I thought I would recreate it with just different titles for the function and id name.
I also created a event handler function for this as well, but when I did, my map did not show up at all and I got an error that was located in the arcgis javascript api.
any suggestions as to how to create the code to turn this function on and off?
HemingZhu
here is my code:
    showLocation = 1;
   }else{
    showLocation = 0;
   alert("hi");
Why just use onchange handler with a variable to handler the situation using return statment? something like this:
function checkboxChanged(sender, evt)
      if variable...
         return;      // equal to cancel
     else
         do something...
