TOC Example
10882
15
06-04-2014 07:39 AM
jaykapalczynski
Honored Contributor
Trying to get the TOC example working
http://www.arcgis.com/home/item.html?id=9b6280a6bfb0430f8d1ebc969276b109
I downloaded the files ... USING 2.10 ...I get most of the website to display including the map but nothing in the TOC shows up.
I am using the code pretty much using the code from the Source HTML.
I put a few Alerts in the code below...I am getting Alert 1,2,4 BUT for some reason not Alert 3
anyone have any thoughts as to why the TOC is not appearing and why I am not getting into Alert 3
 <!DOCTYPE html> <html>     <head>         <meta http-equiv="Content-Type" content="text/html; charset=utf-8">         <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />         <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>         <title>TOC</title>         <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">         <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.9/js/esri/css/esri.css" />         <link rel="stylesheet" type="text/css" href="src/agsjs/css/agsjs.css" />         <style>             html, body {                 height: 98%;                 width: 98%;                 margin: 0;                 padding: 5px;                 font-family: helvetica, arial, sans-serif;                 font-size: 90%;             }              #leftPane {                 width: 280px;                 overflow: auto             }              /* this line hide layers when out of scale for the inline TOC */             .agsjsTOCOutOfScale {                 /*  display: none;*/             }         </style>         <script type="text/javascript">                      // helpful for understanding dojoConfig.packages vs. dojoConfig.paths:                   // http://www.sitepen.com/blog/2013/06/20/dojo-faq-what-is-the-difference-packages-vs-paths-vs-aliases/                   var dojoConfig = {                     paths: {                       //if you want to host on your own server, download and put in folders then use path like:                             agsjs: location.pathname.replace(/\/[^/]+$/, '') + '/src/agsjs'                         }                   };         </script>          <script src="https://js.arcgis.com/3.8/">         </script>          <script type="text/javascript">             var map, toc, dynaLayer1, dynaLayer2, featLayer1;              require(["dojo/_base/connect",     "dojo/dom", "dojo/parser","dojo/on", "dojo/_base/Color",     "esri/map",     "esri/geometry/Extent",     "esri/layers/FeatureLayer",     "esri/layers/ArcGISTiledMapServiceLayer",     "esri/layers/ArcGISDynamicMapServiceLayer",     "esri/symbols/SimpleFillSymbol",     "esri/renderers/ClassBreaksRenderer",     "agsjs/dijit/TOC",     "dijit/layout/BorderContainer",     "dijit/layout/ContentPane",     "dojo/fx", "dojo/domReady!"], function(connect,  dom, parser, on,Color,     Map, Extent, FeatureLayer, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,     SimpleFillSymbol,ClassBreaksRenderer,     TOC){                // call the parser to create the dijit layout dijits               parser.parse(); // note djConfig.parseOnLoad = false;                map = new Map("map", {                 basemap: "topo",                 center: [-85.75, 38.25],                 zoom: 13               });    dynaLayer1 = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyOperationalLayers/MapServer", {         opacity: 0.8               });               featLayer1 = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/1", {                 mode: FeatureLayer.MODE_SNAPSHOT,                 outFields: ["POP07_SQMI"]               });               featLayer1.setDefinitionExpression("STCOFIPS='21111'"); //Louisville, KY  alert("1");        map.on('layers-add-result', function(evt){                 // overwrite the default visibility of service.                 // TOC will honor the overwritten value.                  dynaLayer1.setVisibleLayers([2, 5, 8, 11]);                 //try {                    toc = new TOC({                     map: map,                     layerInfos: [{                       layer: featLayer1,                       title: "FeatureLayer1"                     }, {                       layer: dynaLayer1,                       title: "DynamicMapServiceLayer1"                       //collapsed: false, // whether this root layer should be collapsed initially, default false.                       //slider: false // whether to display a transparency slider.                     }]                   }, 'tocDiv');                   toc.startup();  alert("2");                    toc.on('load', function(){ alert("3");            if (console)                       console.log('TOC loaded');                     dom.byId("ChangeFeatureRenderer").disabled = false;                     dom.byId("SetVisibleLayersProgramatically").disabled = false;                     dom.byId("FindNodeByLayer").disabled = false;                     dom.byId("InsertNewLayer").disabled = false;      dom.byId("HandleNodeCheckEvent").disabled = false;                    });                  //} catch (e) {  alert(e); }               });                map.addLayers([dynaLayer1, featLayer1]);  alert("4");    // REMOVED ACTIONS HERE ARE IN THE NEXT POST               });         </script>     </head>     <body class="claro">         <div id="content" data-dojo-type="dijit/layout/BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">             <div id="header" data-dojo-type="dijit/layout/ContentPane" region="top">                 <div>                     <b>Table Of Content (TOC/Legend) Widget</b>                     <a href='toc_classic.html'>Classic Style </a>                     | <a href='toc.html'>AMD style</a>                     <div style="right:20px;position: absolute">                         <a href="../docs/toc/examples.html">Documentation</a>                     </div>                 </div>                 <ul style="margin:2px">                     <li>                         Click check box in TOC to turn on/off layers. When click on groups, all sublayers will be turned on/off.                     </li>                     <li>                         Click                         <button id="ChangeFeatureRenderer" disabled="disabled">                             ChangeFeatureRenderer                         </button>, notice in "FeatureLayer1", TOC refreshed to reflect the new renderer of FeatureLayer.                     </li>                     <li>                         Click                         <button id="SetVisibleLayersProgramatically" disabled="disabled"">                             SetVisibleLayersProgramatically                         </button>                         to programatically turn layer on/off (Set DynaLayer1 [8, 17, 18, 19, 20] on), notice TOC automatically sync with model(no refresh needed).                     </li>                     <li>                         Click                         <button id="FindNodeByLayer" disabled="disabled">                             FindNodeByLayer                         </button>                         to programatically find node for layer inside a map service, then either hide (layer id=12,"Damage Assessment") or collapse (layer id=0,"Public Safety") it.                     </li>                     <li>                         Click                         <button id="InsertNewLayer" disabled="disabled">                             InsertNewLayer                         </button>                         to programmtically insert a layer (DynamicMapServiceLayer2, Census) then refresh TOC.                     </li>      <li>                         Click                         <button id="SetOpacity" disabled="disabled">                             SetOpacityProgramitically                         </button>                         to programmtically set transparency of a newly added layer to 0.2 with slider enabled (after click "InsertNewLayer").                     </li>      <li>                         Click                         <button id="HandleNodeCheckEvent" disabled="disabled">                             HandleNodeCheckEvent                         </button>                         Handle Check Event to allow only one layer visible in "public saftety" service. When a layer is checked on, all other layers are off.                     </li>                 </ul>             </div>             <div data-dojo-type="dijit/layout/ContentPane" id="leftPane" region="left" splitter="true">                 <div id="tocDiv">                 </div>             </div>             <div id="map" data-dojo-type="dijit/layout/ContentPane" region="center">             </div>         </div>     </body> </html>
jaykapalczynski
Honored Contributor
Got it...Was an order thing...
Was this
<!-- Reference the js frame work from ESRI-->
<script src="https://js.arcgis.com/3.9/"></script>
var dojoConfig = {
    paths: {
</script>
Not this
var dojoConfig = {
     paths: {
</script>
KenBuja
MVP Esteemed Contributor
The code worked properly for me (after I changed the path for agsjs) when I ran it through Visual Studios. But when I copied it over to JSBin, the toc.on load function didn't fire. Then I commented out the other alerts and it ran properly.
One other thing I noticed (but had no effect on it) is you're using the 3.8 JSAPI, but you're using 3.9 stylesheets.
RichardMoussopo
Hi Ken,
I am trying to implement this TOC widget in my APP but I am having issue with the path in visual studio. I am wondering how you set up your path...
I have the folder css in my Application:
and in my default page I have this script
        var dojoConfig = {
            paths: {
    </script>
here is the error I am getting
KenBuja
This is how I have it set up in my applications. This is for biomapper.html
    <script>
        var dojoConfig = {
            parseOnLoad: true,
            packages: [
                    location: location.pathname.replace(/\/[^/]+$/, "") + '../../_assets/agsjs'
                    //"location": 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs' // for xdomain load
                    location: location.pathname.replace(/\/[^/]+$/, "") + "/modules"
                    location: location.pathname.replace(/\/[^/]+$/, "") + "/dijits"
    </script>
And the directory structure looks like this
jaykapalczynski
Honored Contributor
really weird....I ran this in IE and it ran fine?????  Chrome is where I was having issues...
hmmmmm
jaykapalczynski
Honored Contributor
In IE I had to click "SHOW ALL CONTENT" and then everything showed up..
still cant get it to show up in Chrome or Firefox????
hmmmmm
KenBuja
Which Chrome version? I've tested the JSBin in IE 10.0.16, Firefox 24.5.0, and Chrome 34.0.1847.137 (gotta love corporate restrictions!) and it worked properly in all three.
jaykapalczynski
Honored Contributor
oopps.....deleted that post....brb
jaykapalczynski
Honored Contributor
Getting a bunch of errors in Chrome....things timing out...not sure why...
anyone help diagnose these errors?
See image below
jaykapalczynski
Honored Contributor
I was able to get it to work in CHROME but I had to select "load unsafe script" not sure why....maybe because I am trying to load http and https, something to do with our certificate?
