TIGERweb Tracts_Blocks
7820
13
07-07-2021 07:05 AM
ChitraKrishnan
I am trying to query the block  service  https://tigerweb.geo.census.gov/arcgis/rest/services/TIGERweb/Tracts_Blocks/MapServer/2 to get block information based on the input criteria - latitude and longitude. I am getting below error
"Unable to load proxy.ashx?https://tigerweb.geo.census.gov/arcgis/rest/services/TIGERweb/Tracts_Blocks/MapServer/2?f=json status: 500"
if anybody has resolved this issue, please let me know.
Chitra
ChitraKrishnan
@RobertScheitlin__GISP
It works!!!!! that is cool!!!! Thank you very much Robert.
I will try to figure out the color intensity part. If not, will come back for ideas.
Thank you
Chitra
ChitraKrishnan
Hi Robert,
The outline color is not setting to black in below code. We are using js.arcgis.com/3.14. Do I have to do anything different for this version?
gra.setSymbol(
new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 0]), 2),
color
Chitra
Chitra
@ChitraKrishnan  3.14 does not have the clone method on the Graphic class so you have to make some code changes:
<!DOCTYPE html>
<html>
<head>
  <title>Census Blocks</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.14/dijit/themes/tundra/tundra.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.14/esri/css/esri.css">
  <style>
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script src="https://js.arcgis.com/3.14/"></script>
  <script>
    var map, GL, pntsArr;
    require([
      "esri/map", "esri/tasks/QueryTask", "esri/SpatialReference",
      "esri/tasks/query", "esri/geometry/Point", "esri/dijit/PopupTemplate",
      "esri/layers/GraphicsLayer", "esri/graphic",
      "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer",
      "esri/Color", "dojo/domReady!"
    ], function (
      Map, QueryTask, SpatialReference,
      Query, Point, PopupTemplate,
      GraphicsLayer, Graphic,
      SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer,
      Color
      map = new Map("mapDiv", {
        basemap: "streets",
        center: [-83.0014423, 39.9593239],
        zoom: 14,
        slider: false
      var popupTemplate = new PopupTemplate({
          title: "{NAME}",
          fieldInfos: [{
              fieldName: "BLOCK",
              visible: true,
              label: "Block: "
              fieldName: "CENTLAT",
              visible: true,
              label: "Latitude: "
              fieldName: "CENTLON",
              visible: true,
              label: "Longitude: "
      GL = new GraphicsLayer({id: 'mygl', infoTemplate: popupTemplate});
      map.addLayer(GL);
      var arrayFromDatabase = [[-83.0014423,39.9593239],[-83.0006330,39.9597960],[-83.0019028,39.9617077]];
      queryBlocks(arrayFromDatabase);
      function queryBlocks(dbArr) {
        var q = new Query();
        q.outSpatialReference = new SpatialReference(102100);
        q.returnGeometry = true;
        q.outFields = ["*"];
        var qt = new QueryTask("https://tigerweb.geo.census.gov/arcgis/rest/services/TIGERweb/Tracts_Blocks/MapServer/2");
        dbArr.map(function (pntData){
          var pnt = new Point(pntData);
          q.geometry = pnt;
          qt.execute(q, function (result) {
            result.features.map(function (f) {
              var randomColor = '#' + Math.floor(Math.random() * 16777215).toString(16);
              var color = new Color(randomColor);
              color.a = 0.5;
              var gra = new Graphic(f.toJson());
              // console.info(gra.attributes);
              gra.setSymbol(
                  new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0,0,0]), 2),
                  color
              GL.add(gra);
  </script>
</head>
<body>
  <div id="mapDiv"></div>
</body>
</html>
ChitraKrishnan
@RobertScheitlin__GISP  Thank you very much. I will try this.
Chitra
