the problom about missing points
2991
12-21-2015 01:30 AM
Hone-JayChu
Dear friends,
From the web,
https://developers.arcgis.com/javascript/jssamples/layers_csv.html
the points will disappear  based on the sample file using html.
But it works using Sandbox.
Could you tell us the solution about this?
Best reagrds,
HJ
RobertScheitlin__GISP
HJ,
  The code has these lines that are expecting a proxy to be in the site folder.
        urlUtils.addProxyRule({
          proxyUrl: "/Proxy/proxy.ashx",
          urlPrefix: "earthquake.usgs.gov"
So you need a proxy setup on your web server and you need to have the http://earthquake.usgs.gov/ setup as one of the approved server urls.
http://blogs.esri.com/esri/supportcenter/2015/04/07/setting-up-a-proxy/
