The editor widget is not working in the arcgis map
1140
02-17-2023 02:59 AM
gtnishaa7
Can someone help me troubleshoot an issue with the editor widget in the arcgis map built using react? After adding the editor widget, all I see is a white blank rectangle in place of the editor widget. I'm not sure what the problem is, but I have attached a screenshot of the map. Can anyone identify the reason for this issue?
ReneRubalcava
Esri Frequent Contributor
Since this is react, if you could provide a stackblitz or codesandbox, maybe a github repo. If you could simplify it down to reproducing without react in a codepen, even better. But other than that, no way to tell what the issue is.
