Symbology and reference scale in editing Web Service
1492
06-11-2012 03:22 AM
FranziN_
Hi all,
I have an editing web service that work's fine, except from two problems I can't resolve:
1) The order/sorting of subelements (that has been defined in the advanced symbology dialog of the mxd-document) within one feature layer does not appear correctly in the editor panel - the elements are unsorted.
2) The reference scale, set in the mxd-document, doesn't work either in the web service.
Both problems don't occur in the "normal", non-editing web services - only when working with the editor widget and feature layers. Are these non supported functions when working with feature layers or ArcSDE feature classes?
Thanks in advance!
HemingZhu
Hi all,
Thanks in advance!
Does this happen when you set up a featurelayer through map service (like: /mapserver/0)?
FranziN_
Yes, I'm using feature layer for this web service.
HemingZhu
Sorry,  I am not clear on this. I mean you define the featurelayer url: as http://............/FeatureServer/0 OR http://................./MapServer/0 ?
FranziN_
Hi hzhu,
sorry, didn't know what you meant. --> I'm using ".../FeatureServer/0".
iznally
