3.0 issues with custom modules
1767
06-17-2012 03:54 PM
JohnCartwright
Hello All,
I'm using both local and remote custom modules.  In 2.x, my dojoConfig was like:
var dojoConfig = {
   parseOnLoad: true,
   baseUrl: './',
   modulePaths: {
      'help_panel': 'http://maps.ngdc.noaa.gov/viewers/dijits/help_panel/1.1',
      'nos_hydro': './src/dijits/nos_hydro'
Attempting to convert to 3.0, I changed to:
var dojoConfig = {
   parseOnLoad: true,
   modulePaths: {
   packages: [{
      "name": "nos_hydro",
      "location": location.pathname.replace(/\/[^/]+$/, "") + "/src/dijits/nos_hydro"
which works for the local module but not the remote.  I also tried
var dojoConfig = {
   parseOnLoad: true,
   packages: [{
      "name": "help_panel",
      "location": "http://maps.ngdc.noaa.gov/viewers/dijits/help_panel/1.1"
but that didn't work either.  I've tried both the remote module as a Dojo 1.6 CDN build and as plain JS.
Can someone please provide me some guidance here?
Thanks!
--john
derekswingley1
Add a slash to the end of the location for help_panel?
For your help_panel package, what are the URLs you're seeing generated for your module(s) from your app?
ReneRubalcava
Esri Frequent Contributor
I add that package in a test app real quick and used a dojo.require "help_panel.HelpPanel" and the js file was downloaded in my app. I don't know what it does or how to use it, but it downloaded.
The only thing different in my dojoConfig is I have async: true, but I don't know if that would make a difference in this case.
JohnCartwright
Thanks for your reply Derek.  Adding the trailing slash doesn't seem to make any difference.  If the "dojo.require("help_panel.HelpPanel" line is reached, the page doesn't draw.
The URL for the HelpPanel (http://maps.ngdc.noaa.gov/viewers/dijits/help_panel/1.1//HelpPanel.js) is resolving OK.
--john
JohnCartwright
Thanks for your reply Rene.  Adding
async: true
to my dojoConfig causes the error:
Uncaught TypeError: Object #<Object> has no method 'require'
I'm assuming that I need a different require statement and not simply
dojo.require('help_panel.HelpPanel');
when using async.
--john
