Hi, is it possible to dynamically switch the container id of a map? For example, if we create two div container (div1 and div2), can we create a button in order to show the same map on the div1 or on the div2.
I was just preparing an alternative to Jake's examples, showing how to move a existing map from div to div which maintains any changes to the extent.
Edit fiddle - JSFiddle
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Sample Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.15/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css"> <style> html, body { height: 99%; width: 99%; } #divMap{ height: 100%; } #leftPane { width: 48%; } #header { border: solid #C0C0C0 2px; background-color: #C0C0C0; } .div1ButtonStyle { width: 16px; height: 16px; } .div2ButtonStyle { width: 16px; height: 16px; } </style> <script src="http://js.arcgis.com/3.15/"></script> <script> var map; require([ "dojo/parser", "esri/map", "dojo/on", "dojo/dom-construct", "dijit/Toolbar", "dijit/form/Button", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer", "dojo/domReady!" ], function ( parser, Map, on, domConstruct ) { parser.parse(); var map = new Map("divMap", { center: [-80.734, 28.297], zoom: 10, basemap: "topo" }); on(dojo.byId("div1Button"), "click", function () { domConstruct.place("divMap", "rightPane"); }) on(dojo.byId("div2Button"), "click", function () { domConstruct.place("divMap", "leftPane"); }) }); </script> </head> <body class="tundra"> <div id="content" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width: 100%; height: 100%; margin: 0;"> <div id="header" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'"> <div id="navToolbar" data-dojo-type="dijit/Toolbar"> <div data-dojo-type="dijit/form/Button" id="div1Button" data-dojo-props="iconClass:'div1ButtonStyle'">Show Map in Right Pane</div> <div data-dojo-type="dijit/form/Button" id="div2Button" data-dojo-props="iconClass:'div2ButtonStyle'">Show Map in Left Pane</div> </div> </div> <div id="leftPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"> <div id="divMap"></div> </div> <div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
Hi Sebastien,
Yes, this is possible. Below is an example:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Sample Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.15/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css"> <style> html, body { height: 99%; width: 99%; } #leftPane { width: 48%; } #header{ border: solid #C0C0C0 2px; background-color:#C0C0C0 } .div1ButtonStyle { width: 16px; height: 16px; } .div2ButtonStyle { width: 16px; height: 16px; } </style> <script src="http://js.arcgis.com/3.15/"></script> <script> var map; require([ "dojo/parser", "esri/map", "dojo/on", "dijit/Toolbar","dijit/form/Button", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer", "dojo/domReady!" ], function( parser, Map, on ) { parser.parse(); on(dojo.byId("div1Button"), "click", function(){ var map = new Map("leftPane", { center: [-80.734, 28.297], zoom: 10, basemap: "topo" }); document.getElementById("rightPane").innerHTML = ""; }) on(dojo.byId("div2Button"), "click", function(){ var map = new Map("rightPane", { center: [-80.734, 28.297], zoom: 10, basemap: "topo" }); document.getElementById("leftPane").innerHTML = ""; }) }); </script> </head> <body class="tundra"> <div id="content" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width: 100%; height: 100%; margin: 0;"> <div id="header" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'"> <div id="navToolbar" data-dojo-type="dijit/Toolbar"> <div data-dojo-type="dijit/form/Button" id="div1Button" data-dojo-props="iconClass:'div1ButtonStyle'">Show Map in Div1</div> <div data-dojo-type="dijit/form/Button" id="div2Button" data-dojo-props="iconClass:'div2ButtonStyle'">Show Map in Div2</div> </div> </div> <div id="leftPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"> </div> <div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
Hi Jake,
Thanks for the answer, but I would like to switch the same map between the div. On your example you create a new map each time you push a button. I want to do as if you create a map on two div in the same time and with the button you control which one is on (therefore the other one is off).
Hi Ken,
Great, it is what I want.
Thank you for the answer.
Great example Ken!
