Street Intersection autocomplete and Auto-populate
4625
05-19-2015 08:11 AM
RichardMoussopo
I have this logic that I would like to implement for streets intersection. As image below, I have a form with 1 textbox and 1 combobox. I would like to autocomplete the textBox while searching a street and then auto populate the combobox with all matching intersect streets. I am using a service that has 2 fields (str1 and str2).
thejuskambi
You can use ComboBox or FilteringSelect and set the property hasDownArrow to false. that way the dropdown will look like textbox and will provide you autocomplete option. I hope you dont have too many records to populate in the dropdown.
thejuskambi
RichardMoussopo
Thank you thejus.kambithejus.kambi​, I was able to achieve this using the FilteringSelect.
thejuskambi
Glad, I could help. you could help me by updating the status of this discussion.
