Start/stop edit layers
2741
12-06-2012 01:11 AM
PatrickChapuis
ArcGIS for Server 10.1
ArcGIS API for JavaScript 3.2
I need to start and stop editing layers. In my application, I can show and hide the editor widget (esri.dijit.editing.Editor) but, after has been started the first time, I cannot stop to edit features.
Here, the using process:
1- start editor
2- click on a feature : I got a popup and I can edit the geometry (vertices, size, ...)
3- stop editor
4- click on a different feature (or the same one), I can still edit the geometry.
Here, the ways to correct it I tried:
- layer.setEditable(false) => "FeatureLayer:setEditable - this functionality is not yet supported for layer in a feature service"
- destroy the editor or the template picker by using many ways  => inefficient
- start/stop the editor object => no way to do (activate/deactivate method don't exist)
Any idea?
JohnGrayson
Esri Alum
I haven't tested this with the latest api, but try this:
editor._updateCurrentFeature(dojo.hitch(this,function(){
  editor._clearSelection(false);
PatrickChapuis
Hi, thanks but it doesn't work. I tried to call your code when I shutdown the editor but maybe should I do it when I click on my feature?
PatrickChapuis
And, for information, this method exists : myEditor.stopEditing()
From /esri/dijit/editing/Editor.js
stopEditing : function(_6) {
 this._updateCurrentFeature(_2.hitch(this,
  function() {
   this._clearSelection(false);
   _6 && _6();
It seems it need a variable but I can't find which kind of
CarlosLopez9
Hi Patrick, how did you know of the existence of stopEditing() and _disableMapClickHandler() method?. Those methods don´t exist in the javascript api Editor | API Reference | ArcGIS API for JavaScript 3.20 . Excuse my English and I appreciate your response.
PatrickChapuis
Ok, after a long time looking in the compiled code, it seems this solution work
Deactivate :
editorWidget.stopEditing(false);
editorWidget._disableMapClickHandler();
Activate :
editorWidget._enableMapClickHandler();
Be carefull to not call _enableMapClickHandler twice
My code:
//var editModeIsEdit (bool) true|false => editing session ?
function manageEditor(){
 if(editModeIsEdit){
  if(editorWidget!=undefined){
 }else{
  if(templatePicker!=undefined){
   templatePicker.clearSelection(false);
