simplerenderer with ESM
1199
04-01-2022 06:36 PM
LefterisKoumis
New with ESM and API 4.x
I hit a wall trying to implement with ESM the simple renderer. What am I missing?
According to the:
https://developers.arcgis.com/javascript/latest/api-reference/esri-renderers-SimpleRenderer.html
the simplerenderer can be imported by:
But, when I try to implement it:
I get this error:
ReneRubalcava
Esri Frequent Contributor
If you are going to use pure ESM via the ESM CDN, you need to add .js to filename.
https://codepen.io/odoe/pen/xxpPppQ?editors=0010
Normally when using ESM, you would use build tools that don't need the file extension.
ReneRubalcava
