Show InfoWindow on Table Selection
1968
6
11-19-2014 09:23 AM
WesAskew
I am trying to show the infowindow of a point when the specific point's OBJECTID is clicked on in a table.  I am able to get a blank infowindow to show, but no title or attributes are displayed.  Could someone please direct me to what I am missing? The function that I am currently calling is attached.  Any help is greatly appreciated!  Thanks in advance.
RobertScheitlin__GISP
Wesley,
  I had to put together a sample to figure out what was going wrong. Here is your corrected function, lines 13, 17 and 18 are the fix (use InfoTemplate instead of PopupTemplate).
   function selectSite(e) {
            // select the feature
            var queryGrid = new Query();
            queryGrid.objectIds = [e.target.innerHTML];
            sitesQuery.selectFeatures(queryGrid, featureLayer.SELECTION_NEW, function(result) {
              if (result.length > 0) {
                // re-center the map to the selected feature
               var pt = result[0];
               var ptGeom = result[0].geometry;
               var factor = 10; //some factor for converting point to extent
               var newExtent = new Extent(ptGeom.x - factor, ptGeom.y - factor, ptGeom.x + factor, ptGeom.y + factor, ptGeom.spatialReference);
               map.setExtent(newExtent);
               var template = new InfoTemplate({title: "Site"});
               template.setContent("<tr><b>Facility: </b><td>${FAC_NAME}</tr><br><tr><b>Address: </b><td>${ADDRESS_1} ${CITY}, ${STATE_CODE} ${ZIP_CODE}<br><tr><b>Contamination Type: </b><td>${CONTAM_TYPE}</tr></td><br><tr><b>Latitude: </b><td>${LAT_DECIMAL}</tr></td><br><tr><b>Longitude: </b><td>${LONG_DECIMAL}</tr>");
               pt.setInfoTemplate(template);
               map.infoWindow.setFeatures([pt]);
               map.infoWindow.show(ptGeom);
              } else {
                alert("Select an OBJECTID to Zoom to Feature");
Wesley,
   Are you sure that "e.target.innerHTML" is actually getting the ObjectID?
Did you try a console.info(e.target.innerHTML);
WesAskew
Thanks for your response. Yes, e.target.innerHTML returns the proper ObjectID. I also checked the ObjectID of the associated graphic by using alert(pt.attributes.OBJECTID);. Something seems to be missing when creating the infowindow that prevent the attributes from displaying.
Wesley,
   So does the sitesQuery FeatureLayer have FAC_NAME, ADDRESS_1, etc, etc in its out fields?
Have you tried to print the pt.attributes to the console?
WesAskew
Yes, all necessary attributes are present and will print to the console.
Wesley,
               var pt = result[0];
              } else {
WesAskew
Thanks a lot!  I figured it was something simple but could not determine what.
