I have a question. In this example they explain how to display result in a datagrid: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htmBut that is only possible with the fixed tableheader id's like: <th field="PARCELID">Parcel ID</th> <th field="OWNERNME1" >Owner 1</th> <th field="OWNERNME2">Owner 2</th> <th field="RESYRBLT ">Year Built</th> <th field="SITEADDRESS" width="100%">Address</th>But i cant use this, because i use different find tasks with different parameters.So i found this example: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/fl_query_relat...But in this example is one thing that doesnt work: and that's the identifier. If you click on any of the results in the datagrid ( with mfind tasks) then the setExtent doesnt pick the right one. It only picks the last found in the datagrid.Does anyone know what im doing wrong?Here's my code: function doFind() {
var e = document.getElementById("QueryPicker");
var strUser = e.options[e.selectedIndex].value;
if (strUser==="Sporen"){
findTask = new esri.tasks.FindTask("https://gis.strukton.com/ArcGIS/rest/services/ProRail_Data/MapServer");
var findParams = new esri.tasks.FindParameters();
findParams.returnGeometry = true;
findParams.layerIds = [31];
findParams.searchFields = ["NR", "GeoSpoor"];
/*var gridTable = document.getElementById("grid1");
//gridTable.style.display = 'none';
gridTable.style.visibility="hidden";
var gridTable1 = document.getElementById("grid");
gridTable1.style.visibility="visible";*/
findParams.outSpatialReference = map.spatialReference;
findParams.searchText = dojo.byId("ownerName").value;
findTask.execute(findParams,showResults);
else if (strUser==="Wissels"){
findParams.layerIds = [33];
findParams.searchFields = ["NR", "GeoWisselNR1", "GeoWisselNR2"];
else if (strUser==="sein"){
findParams.layerIds = [23];
findParams.searchFields = ["NUMMER", "GEOCODE"];
/*var gridTable = document.getElementById("grid");
var gridTable1 = document.getElementById("grid1");
else if (strUser==="bovenleidingpaal"){
findParams.layerIds = [26];
else if (strUser==="Spoortoegang"){
findTask = new esri.tasks.FindTask("https://gis.strukton.com/ArcGIS/rest/services/POI_Data/MapServer");
findParams.layerIds = [0];
findParams.searchFields = ["ToegangsNR"];
else if (strUser==="Kilometrering"){
findParams.layerIds = [20];
findParams.searchFields = ["GEOCODET"];
else if (strUser==="Geocode"){
findParams.layerIds = [48];
findParams.searchFields = ["GeocodeTekst"];
function showResults(results) {
//This function works with an array of FindResult that the task returns
var markerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 10,
new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
new dojo.Color([0,255,255]), 2),
new dojo.Color([0,255,0,0]));
var lineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
new dojo.Color([0,255,255]), 4);
var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
new dojo.Color([0,255,255]), 4),new dojo.Color([0,255,255,0]));
//find results return an array of findResult.
map.graphics.clear();
var dataForGrid = [];
//Build an array of attribute information and add each found graphic to the map
dojo.forEach(results, function(result) {
var graphic = result.feature;
dataForGrid.push([result.foundFieldName, result.value]);
switch (graphic.geometry.type) {
case "point":
graphic.setSymbol(markerSymbol);
break;
case "polyline":
graphic.setSymbol(lineSymbol);
break;
case "polygon":
graphic.setSymbol(polygonSymbol);
break;
map.graphics.add(graphic);
var data = {
items: dataForGrid
var store = new dojo.data.ItemFileReadStore({
data: data
grid.setStore(store);
//Zoom back to the initial map extent
function onRowClickHandler(evt){
//symbology for graphics
var clickedTaxLotId = grid.getItem(evt.rowIndex).OBJECTID;
var selectedTaxLot;
dojo.forEach(map.graphics.graphics,function(graphic){
if((graphic.attributes) && graphic.attributes.OBJECTID === clickedTaxLotId){
selectedTaxLot = graphic;
return;
if ( selectedTaxLot.geometry.declaredClass == 'esri.geometry.Point' ) {
var PointExtent = new esri.geometry.Extent();
PointExtent.xmin = selectedTaxLot.geometry.x - 100; //I'm using State Plane Feet, so that's 100 out from my point
PointExtent.ymin = selectedTaxLot.geometry.y - 100;
PointExtent.xmax = selectedTaxLot.geometry.x + 100;
PointExtent.ymax = selectedTaxLot.geometry.y + 100;
map.setExtent(PointExtent);
//map.centerAndZoom(selectedTaxLot.geometry);
//map.setExtent(sp.getExtent().expand(3));
// map.infoWindow.show(selectedTaxLot.geometry, map.getInfoWindowAnchor(sp));
else{
var taxLotExtent = selectedTaxLot.geometry.getExtent();
map.setExtent(taxLotExtent);
//map.setExtent(mappoint);
And some HTML:<div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'" style="height:350px;" >
<table data-dojo-type="dojox.grid.DataGrid" jsid="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
<thead>
<tr>
<th field="0" width="auto" >
Gezocht op
</th>
<th field="1" width="auto" >
Gevonden
</th>
</tr>
</thead>
</table>
</div>
</div>
