Setting Initial Extent
2651
02-15-2016 08:10 AM
EdwardDean
I am new to Javascript and working with the ArcGIS for Javascript API. I recently completed an abbreviated version of the Developing Web Apps with ArcGIS, API for Javascript course and I am going back through the lesson for review. I am trying to set the initial extent in a lesson and it is not working. I don't know what I am doing wrong. Any help would be greatly appreciated.
Thanks in advance.
Ed Dean
thejuskambi
// Create the map
      mapMain = new Map("cpCenter", {
        basemap: "satellite",
        extent: "extentInitial"
you are passing the variable as string. you need it as below
// Create the map
        extent: extentInitial
thejuskambi
// Create the map
// Create the map
EdwardDean
Thank you very much! This worked
