Set infoWindow title with html element
2491
12-21-2016 01:54 PM
NhuMai
I am trying to add an combobox to the title of an infoWindow. The combobox is intended to be populated with the list of identified results. I'm trying two different ways:
1. Adding the combobox declaratively using html:
var template = new esri.InfoTemplate(layerName + "<br/><select id="id_select" data-dojo-type="dijit/form/Select"</select>,"<br/> FID : ${FID}");
The combobox is there, but I don't know how to access the combobox to add the options dynamically (via addOptions). I would normally do dijit.byId("id_select"), but considering it doesn't exist until it's created...I'm not sure how to go about this way.
2. Programmatically
With the code below, the title displays information regarding the dijit/form/select widget (It displays: [object HTML TableElement]), but not the widget itself. I tried using domConstruct like this example.
var identifyTask, identifyParams, idPoint;
var identifyResults;
require([
 "esri/dijit/Popup",
 "esri/tasks/IdentifyTask",
 "esri/tasks/IdentifyParameters",
 "dijit/form/Select",
 "dojo/dom-construct",
 "dojo/promise/all",
 "dojo/domReady!"
], function (
 Popup, IdentifyTask, IdentifyParameters, Select, domConstruct, All
 var identifySelect;
//dojo.connect(window.myMap, "onLoad", mapReady);
 mapReady(window.myMap);
function mapReady(map) {
 dojo.connect(window.myMap, "onClick", runIdentifies);
function runIdentifies(evt) {
 identifyResults = [];
 idPoint = evt.mapPoint;
 var layers = dojo.map(window.myMap.layerIds, function (layerId) {
 return window.myMap.getLayer(layerId);
 layers = dojo.filter(layers, function (layer) {
 if (layer.visibleLayers[0] !== -1) {
 return layer.getImageUrl && layer.visible
 }); //Only dynamic layers have the getImageUrl function. Filter so you only query visible dynamic layers
 var tasks = dojo.map(layers, function (layer) {
 return new IdentifyTask(layer.url);
 }); //map each visible dynamic layer to a new identify task, using the layer url
 var defTasks = dojo.map(tasks, function (task) {
 return new dojo.Deferred();
 }); //map each identify task to a new dojo.Deferred
 var params = createIdentifyParams(layers, evt);
var promises = [];
for (i = 0; i < tasks.length; i++) {
 promises.push(tasks.execute(params)); //Execute each task
var allPromises = new All(promises);
 allPromises.then(function (r) { showIdentifyResults(r, tasks); });
function showIdentifyResults(r, tasks) {
 var results = [];
 var taskUrls = [];
 var resultNames = [];
 r = dojo.filter(r, function (result) {
 return r[0];
 for (i = 0; i < r.length; i++) {
 results = results.concat(r);
 for (j = 0; j < r.length; j++) {
 taskUrls = taskUrls.concat(tasks.url);
 results = dojo.map(results, function (result, index) {
 var feature = result.feature;
 var layerName = result.layerName;
 var serviceUrl = taskUrls[index];
resultNames.push({
 value: result.layerName,
 label: result.layerName
 feature.attributes.layerName = result.layerName;
var identifiedList = getIdentifiedList(resultNames);
 console.log(identifiedList);
var template = new esri.InfoTemplate();
 template.setTitle(identifiedList);
 feature.setInfoTemplate(template);
var resultGeometry = feature.geometry;
 var resultType = resultGeometry.type;
 return feature;
 if (results.length === 0) {
 window.myMap.infoWindow.clearFeatures();
 } else {
 window.myMap.infoWindow.setFeatures(results);
 window.myMap.infoWindow.show(idPoint);
identifySelect.on('change', function(evt) {
 var identIndex = identifySelect.get("value");
 console.log(identIndex);
 window.myMap.infoWindow.select(identIndex);
return results;
function getIdentifiedList(options) {
 identifySelect = new Select({
 options: options
 }, domConstruct.create("select"));
 return identifySelect.domNode;
function createIdentifyParams(layers, evt) {
 var identifyParamsList = [];
 identifyParamsList.length = 0;
 dojo.forEach(layers, function (layer) {
 var idParams = new esri.tasks.IdentifyParameters();
 idParams.width = window.myMap.width;
 idParams.height = window.myMap.height;
 idParams.geometry = evt.mapPoint;
 idParams.mapExtent = window.myMap.extent;
 idParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
 var visLayers = layer.visibleLayers;
 if (visLayers !== -1) {
 var subLayers = [];
 for (var i = 0; i < layer.layerInfos.length; i++) {
 if (layer.layerInfos.subLayerIds == null)
 subLayers.push(layer.layerInfos.id);
 idParams.layerIds = subLayers;
 } else {
 idParams.layerIds = [];
 idParams.tolerance = 5;
 idParams.returnGeometry = true;
 identifyParamsList.push(idParams);
 return identifyParamsList;
RobertScheitlin__GISP
Nhu,
   I have never attempted what you are trying but you should try and use
InfoWindowBase | API Reference | ArcGIS API for JavaScript 3.19 | startupDijits
NhuMai
Thanks for the tip.
After adding the InfoWindowBase requirement, I tried the following:
template.startupDijits(identifySelect)
and
template.startupDijits()
Gives me:
template.startupDijits is not a function
Going to keep searching, but just wanted to keep you posted and see if you had feedback.
Mahalo
What is the template objects class type?
