Set different opacity color fill for a single layer
2814
08-09-2017 05:04 AM
Sai_AnandPeketi1
Hello everyone,
                        I have a layer consist of 8 different categories for each category set a different color code and opacity in desktop and publish in the ArcGIS Server. It working fine in ArcGIS Online. Whenever I using the map services in ArcGIS API for JS the color code is fine, but the opacity is not working. It automatically set 0% transparency and 1  Opacity.
How can I set the different opacity for different categories in a single layer by the help of  ArcGIS API for JS?
Thanks for the help.
RobertScheitlin__GISP
For that you need to look at VisualVariables for renderers:
https://developers.arcgis.com/javascript/3/jsapi/uniquevaluerenderer-amd.html#visualvariables
Sai_AnandPeketi1
Thanks for help Robert. Could give me a sample example.
The attached zip has an example, it is a little complicated but you should be able to pull what you need from it:
Sai_AnandPeketi1
Thank for help Robert. Let me check it.
