Seeking Geocoder Sample with a zoom in to an IdentifyTask
853
10-03-2013 12:49 PM
AveryGomez
Does anyone have a sample you can forward to me where the geocoder zooms to the address and pops up an identifying task?
I know I saw something like this once and am not having any luck locating it again. Please let me know..
Thanks..
TracySchloss
Honored Contributor
I needed to have an identify function that served double duty, running from either a map click or a geocoded point.
I have a Boolean variable set 'idClick'.  I needed this because a click event you need event.mapPoint to determine the geometry for the identifyParameters and geocoding returns geometry already.  Then these lines in my initiating function
        identifyTask = new esri.tasks.IdentifyTask(http://yourserver/ArcGIS/rest/services/serviceName/MapServer");
        identifyParams = new esri.tasks.IdentifyParameters();
        identifyParams.tolerance = 1; //
        identifyParams.returnGeometry = false;
        identifyParams.layerIds = [0,1,2];
        identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
        identifyParams.spatialReference = spatialReference;
        identifyParams.extent = map.extent;
        identifyParams.width = map.width;
        identifyParams.height = map.height;
        dojo.connect(map, "onClick", function () {idFromClick = true;});
        dojo.connect(map, "onClick", executeIdentifyTask);
Here is the execute function
 //identify either from map click or geocoded location
   function executeIdentifyTask(evt) {
      identifyParams.mapExtent = map.extent.expand(0.1);
     identifyParams.geometry = evt; //input from address, evt is already a map point
     var inputPt = evt;
    if (idFromClick) { // input from map click
        identifyParams.geometry = evt.mapPoint;
        inputPt = evt.mapPoint;
      var deferred = identifyTask.execute(identifyParams);
        deferred.addCallback(function(response) {
          return dojo.map(response, function(result) {
            var feature = result.feature;
            var layerName = result.layerName;
            feature.attributes.layerName = result.layerName;
            feature.setInfoTemplate(plainTemplate);
              return feature;
        map.infoWindow.setFeatures([ deferred ]);
        map.infoWindow.show(inputPt); //point type is the same coming from either method
Last you need to call this function at the end of your geocoding results function
       function showResults(candidates) {
            var candidate;
            var symbol = new esri.symbol.SimpleMarkerSymbol();
            var addressTemplate = new esri.InfoTemplate("Location", "Address: ${address}<br />");
            symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
            symbol.setColor(new dojo.Color([255,0,0,0.75]));
                dojo.every(candidates,function(candidate){
                  console.log(candidate.score);
                  if (candidate.score > 80) {
                    console.log(candidate.location);
                    var attributes = { address: candidate.address, score:candidate.score, pt:candidate.location };
                    geometryPt = candidate.location;
                    var graphic = new esri.Graphic(geometryPt, symbol, attributes, addressTemplate);
                    map.graphics.add(graphic);
                    var displayText = candidate.address;
                    map.infoWindow.show(geometryPt);
                  map.infoWindow.setTitle("Address");
                    return false; //break out of loop after one candidate with score greater  than 80 is found.
                map.centerAndZoom(geometryPt,12);
                executeIdentifyTask(geometryPt);
