Search results in different projection than map
1894
10-26-2015 01:44 PM
wcESRI
Hello,
I have a Search object and event with the following code
var myEntryX = myEntryGeometry.x;
var myEntryY = myEntryGeometry.y;
'<!>Your coords are \n' + myEntryX + ', ' + myEntryY + ', ' + myEntryGeometry.spatialReference.wkid);
This yields
<!>Your coords are
I noticed my spatial reference for this data is 102100, which is WGS 1984.  However, this data is being returned with coordinates in meters.
I have data available in 4326, which is WGS 1984 in decimal degrees.  This is also the reference for my layers and map.
Can I get the search object results in 4326, which has the xy coordinates in decimal degrees?
Thanks in advance!
RobertScheitlin__GISP
Christopher,
   WKID 102100 is web mercator the standard for all esri basemaps. the JS API has simple classes to convert 102100 to 4326 it is called webMercatorUtils
