scalebarUnit - Changing the units
2230
02-10-2011 02:35 PM
CarlaYarrow
I'm wondering if anyone knows how to alter the units in Javascript API from 'english' (which gives miles) to kilometers?
var scalebar = new esri.dijit.Scalebar({
            map: map,
            scalebarUnit:'english'
I have tried using 'metric'. No luck! Any help on this one?
JianHuang
Please refer to the doc at:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm#jsapi/scalebar.htm
It documents as:
<String> scalebarUnit  Specify the scalebar units. Valid values are "english" or "metric". The default value is "english".
Thanks.
AdrianMarsden
Honored Contributor
I tried this myself, however it fails
It has both Yards and meters on it - zooming out, just "english" and zooming in further the two units overwrtite each other.  Snippet where I call it below.
        dojo.connect(map, 'onLoad', function(theMap) {
            map: map,
            scalebarUnit:'metric'
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
         //add the overview map
          overviewMapDijit = new esri.dijit.OverviewMap({
            map: map,
   expandFactor:4
          }, dojo.byId('overviewMapDiv'));
          overviewMapDijit.startup();
AdrianMarsden
Honored Contributor
😮 Doh! Note to self - when re-using code from Esri examples and other places, make sure you don't call stuff twice.
I'd re-used some older code wit a scale bar, but had stripped out the initial definition, so it didn't work, then added the whole lot back in - result 2 bars, one metric the other "american" - Note to Esri, here in England we are trying very hard to use metric 😄
JeffPace
We did that in America back in the 80s. It didn't take.
