Sample for query combo box/ drop down select
1561
08-20-2014 10:09 AM
MayJeff
I need a sample to perform select search like this website:
Yavapai Parcel Viewer
When you select the dropdown menu, it will shows your selection option.  When you  select it then it will zoom to the location.  I didn't find any ESRI samples for it.
Thanks.
JakeSkinner
Esri Esteemed Contributor
Hi May,
Here is a quick sample:
Edit fiddle - JSFiddle
RobertScheitlin__GISP
May Jeff,
   You are not going to find samples for everything you want to do. This is just a simple FindTask that is being executed and then zooming to the results. There are plenty of samples for that functionality.
JakeSkinner
Hi May,
MayJeff
Thank you for your sample.
