Routing Directions
1454
03-26-2014 04:39 AM
Vibin_DhasDevadhason
Hi All,
Could in have the source code for Routing Direction in ArcGIS API for JavaScript verison 3.8.  I did the Direction using the guidance of the following url: https://developers.arcgis.com/javascript/jssamples/widget_directions_basic.html.  Even i couldn't find the source code to use my customize MapServices.  It Directly accessing the ArcGIS.com proxy..It would be great getting the replay..
JeffPace
source code of widgets is not available
JeffPace
DavidColey
MVP Frequent Contributor
Jeff's right. Souce code is not available but you can easily plug in your own or esri's routing service into the dijit.  I would begin by looking at the routing paramaters, tasks and results task examples-
Thanks..
