Change the "basemap" option in the Map class
1505
03-26-2014 08:48 AM
SaqibAmin1
Does anyone know how to amend the basemap option below, so that I can add a dynamic map service (...../mapserver) instead of the ArcGISonline map?
I know about  e.g. map.addLayers(dynamicMapService), however I want to see if there is a a way to amend the below.
      map = new Map("map", {
        basemap: "topo"
JeffPace
ralphholmes
add the code
BaseMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer ("rest server location");
map.addLayers([BaseMapLayer])
SaqibAmin1
Thanks for your replies, Jeff and Ralph.
Ralph, I have already tried this method, the dynamic map displays on the page, however I wanted to amend the basemap property in the map object, so that instead of using ArcGISOnline pre-defined maps, my dynamic map services are used as a basemap.
Jeff, I will have a look at the class definitions and see if I can make sense of it.
